Forscan buzz test, by cylinder # or firing order?
14K views 12 replies 4 participants last post by  Hydro
Also, I was trying to do an injector disable test yesterday, found it in the forscan (Windows) but could not execute the test to kill cylinders individually. Is that not an option?
Ayup, that function works fine
this on the 2006 in your sig line ? you didn't start out with that info
Should be in the "vehicle tests" button (left side of the window)
select cylinder cut out and click the "Run" button at the bottom of the window
follow the instructions in the next window
Reactions: bismic
You are in the correct place -- add all the injector disable to the right hand pane and click OK to exit that window
on the main screen you will see a button to the right of the PCM that has an X in it -- click that - a control window will open where you can disable each injector one at a time
