Status
Not open for further replies.
Ford SuperDuty Diagnosis on the Cheap
124K views 113 replies 52 participants last post by  guitarnut
#1 · (Edited)
How To: Super Duty Diagnosis on the Cheap!
This will be a multi-part write-up, covering how to diagnose, monitor, and run tests on Ford Super Duty Trucks, focusing on the Ford 7.3L Super Duty as that is the truck that I own, but these tools work for all Super Duty Trucks.
Warning: Some technology experience may be required
The write-up will go as follows:
PC Based Diagnosis Testing and monitoring with Forscan
Android Based Diagnosis with Forscan Lite
Android based Monitoring with Torque Pro
Android based Self Tests with CarGauge Pro
I will be posting these over the next few days. Starting with PC based Diagnosis.
Disclamer: I have no affiliation with any of the programs or devices mentioned in this article, I am simply a power user.
Edit: Since I am hosting some of these images on my server(forum wont let me post more than 5 images per post). I have created a PDF of my walkthrough in case my server is offline or the images become inaccessible.
Edit 2: V2.0 of the PDF uploaded, includes Android Forscan tutorial
Edit 3: v3.0 of the PDF uploaded, includes Android Torque Pro tutorial
Edit 4: v4.0 of the PDF uploaded, includes Android CarGauge Pro tutorial
#2 · (Edited)
Part 1: PC Based Diagnosis with Forscan
Everyone on this site has heard of AutoEnginuity, It really is an awesome tool, but when I first heard about it I thought it was crazy, I am a big proponent of Open Source Software and decided to see if there was something cheap or free that would work.
Forscan is a piece of free software that I found, it is not open source, but it works really well.
Now on to the how to!
Required Items:
Important Note: This tutorial is written on a PC running windows 8.1 but has been tested on Windows 7, 8, 8.1, and 10.
Step 1: Download and Install Forscan for Windows from their website: http://forscan.org/download.html
Step 2: Connect your USB ELM327 Adapter to your laptop and to your truck.
Step 3: Open Forscan on your laptop
You should be greeted with a screen like this:
Step 4: Connect to your truck for the first time:
Note: If you are not using a usb adapter, make sure your bluetooth adapter is paired with your laptop, forscan SHOULD auto-find and connect to it when you follow these steps.
Click on the connect button circled in red
You will get a popup telling you what is required for it to connect, TURN THE KEY ON, then click OK on that popup.
Step 5: Answer Questions
You will get this popup
Unless your adapter has a physical switch on it click NO
Then you will get this
Click Yes. This creates a profile for your truck. From that point forward anytime you connect the Forscan app will remember your dashboard PID’s, which we will get to in a bit.
Now that we are connected, let’s get to the useful part of this.
DTC checking
Step 1: click on the DTC tab
That will take you to a screen showing you all of your DTC’s, including Ford Specific, and a brief explanation.
You can click on any of these DTC’s to see more details.
Run Self Tests
Click on the self tests button.
Then you will see a list of available self tests.
Pick whichever one you want to run and then click the red circled play button, the interface will walk you through them. These self-tests are explained in many places on the forums, I will not be re-explaining them here.
Monitoring with Forscan
One of the most common things to do with your OBD interface is to monitor parameters in the truck to test for things like a Failing ICP/IPR.
To monitor your truck you will connect as described above.
After that, click on the dashboard icon.
You will see the following screen
But that doesn’t really help, there is no info there!
Double click on any of the white boxes and you will get a popup
Scroll around and find whatever you would like to monitor. There is more here than the 7.3 supports, so some may not work. When you find one you want to monitor, simply double click on it. When you are done, click the checkmark at the bottom of the popup.
That will take you back to the datalog screen. To start actually viewing data click the play button I have circled below.
This is how the data will look.
This concludes the PC Forscan part of this Tutorial. Next up, android!
#3 · (Edited)
Part 2: Android based Diagnosis with Forscan Lite
Disclaimer: This tutorial is written with screen shots from a Samsung Galaxy Note 4, but has been tested on half a dozen different phones.
Required items:
Bluetooth OBD Reader(I use this one: http://goo.gl/aVPJLa )
Android Phone or Tablet
Super Duty truck!
Now, to start we need to buy the Forscan Lite app. There is a free app that you can use for testing, this tutorial does not cover that.
Step 1: Open the google play store, search for Forscan Lite, purchase and install it.
Step 2: Connect your Bluetooth obd reader to your truck and turn the key on.
Step 3: Pair your OBD reader to your phone
Your phone will ask you for a Bluetooth pin, usually this is 0000 or 1234
Step 4: Open the Forscan app
Step 5: Configure the app, scroll down to settings, click settings
Step 6: In the settings menu make sure Demo mode is not selected and your OBD reader is selected.
Step 7: Connect to the truck.
Wait for the light to turn green
Step 8: Select Errors
Step 9: See what DTC’s your truck has.
The Red Circle clears ALL DTC’s, the Green Circle re-scans for any DTC’s.
Step 10: Disconnect
Click the button in the green circle to disconnect when done.
Save
#4 · (Edited)
Part 3: Monitoring with Torque Pro
Required items:
Super Duty truck!
Now, to start we need to buy the Torque Pro app. There is a free app that you can use for testing, this tutorial does not cover that.
Step 1: Open the google play store, search for Torque Pro, purchase and install it.
Step 4: Open the Torque Pro app
Step 5: Open torque settings to configure the app.
Step 6: Click on Settings
Step 7: scroll down on the screen until you find and click on “Manage Extra PIDs/Sensors”
Step 8: click on the menu button in the top right
Step 9: Click on “Add Predefined Set”
Step 10: click on “Ford (Incl. Powerstroke)”
Step 11: Verify you see a large # of new PID’s on the screen
Step 12: Press the back button to get back to the settings screen, then click on “OBD2 Adapter Settings”
Step 13: Verify connection type, choose Bluetooth device if you wish, Torque will auto find OBD readers if you do not pick.
Step 14: Back all the way out to the home screen of the torque app.
Verify that Torque connects to your reader.
The Red Circle is your GPS Lock, does not matter for monitoring
The Green Circle is your device indicator, it should always be lit
The Blue Circle is connection to OBD reader
The Orange Circle is the OBD reader’s connection to the PCM
Step 15: Click on realtime information
Step 16: Note that you can swipe left and right to get to an empty screen of gauges
Step 17: press and hold on the screen until you see a popup, then click add display
Step 18: Select the type of display you want, I like Dial (needle)
Step 19: Pick the PID you want, for Example ICP
Step 20: Pick a size
Step 21: tap the location you want the gauge, you can also drag it to the grid lines
Step 22: When you tap or release your finger the gauge will lock there.
Repeat steps 17-22 for each gauge you want to add.
Save
#5 · (Edited)
Part 4: Testing with CarGauge Pro
Required items:
Super Duty truck!
Now, to start we need to buy the CarGauge Pro app. There is a free app that you can use for testing, this tutorial does not cover that.
Step 1: Open the google play store, search for Car Gauge Pro, purchase and install it.
Step 4: Open the CarGauge Pro app
Step 5: Click on connect.
Step 6: Select your OBD reader from the popup
Step 7: Select your vehicle manufacturer (FORD!! :icon_ford: )
Step 8: Select the Ford Powertrain Module
Step 9: Select the ECU
Step 10: Select Auto-Scan for PID’s
Step 11: click cancel when asked to save the PID list
Step 12: Click Diagnostics
Step 13: Select Self Test
Step 14: Select the test you want to run, for example a Buzz Test
Step 15: let the test run until the red goes away
Step 16: Observe any leftover P codes, deal with accordingly
Step 17: Press back button back to the home screen, then press exit when done.
Save
#6 · (Edited)
What about my iPhone?
I do not own any fruit company products(Apple OR Blackberry). If someone wants to work with me I am sure we can develop similar procedures for Fruit Devices.
More FAQ's to come as people post.
Save
#7 ·
So these all basically give you the same information? Any advantages of one method over another? Thanks.
Save
#8 ·
The PC version of Forscan gives you the same information as the 3 apps combined.
Each android app is best suited to a specific function. Forscan Lite works awesome as a code puller, Torque Pro is the best dashboard app/monitoring app around, and CarGauge Pro is the only app I know of that allows you to run the self tests, but it is terrible at code pulling and monitoring.
Save
#9 ·
Very good info! Certainly subscribing for the updates!
Save
#11 ·
Coming soon(will get pics this weekend, probably post Tuesday): How to do Data Logging so you can monitor while riding solo! Torque Pro is awesome for seeing your gauges at a glance, it is what I use, but Forscan Lite has a datalog feature that allows you to go back in time and review, which is useful!
Save
#12 ·
Only issue I see is in post 5 it starts saying torque pro and then it says car gauge for the rest of the post.
Reactions: scoutcamper
Save
#13 ·
Whoops, that is now fixed. Thanks!
Save
#14 ·
I have a tip for those when hooking up too your OBDII port, I took out the 2 mounting screws, and moved mine around so the adapter is not sticking down, it's parallel too the bottom of the dash, and not sticking down.
Save
#15 ·
Bumping thus up. Should be a sticky
Save
#16 ·
Save
#17 ·
Since I have received some feedback that some people don't like the Torque Pro app I will be writing up how to use ForScan Lite on Android to monitor(and datalog, allowing you to review your data). It works very well, but does not have the selection of skins and gauge types that Torque Pro has.
Save
#18 ·
Hey guys, sorry its taking so long to get the next guide posted, my day to finish it up(today) was spent taking the truck to my mechanic to get my leaky injector cup fixed :(
I get the truck back Friday, so hopefully I can get the guide written up and posted by Sunday.
In the meantime I am happy to answer any questions anyone might have on this...
Reactions: woodbutcher2005
Save
#19 ·
Just a quick question: is the injector electrical test on the ForScan the same as the buzz test on the car guage pro? If not, does the ForScan offer a buzz test, or only what is shown in your screenshot?
Save
#20 ·
Injector Electrical Test is a Buzz Test, I dont know why they dont use the same term...
Save
#21 ·
waiting ..for this one .definitely subscribing
Save
#22 ·
Bump this up for reference.
Save
#23 ·
Can we get this out up as a sticky, mods?
Reactions: john galt
Save
#24 ·
Reactions: Heavy_GD
Save
#25 ·
has any body seen the new ..scoutcamper said it would be up last wk ..and I don't see it ..am I missing it..or are we all still waiting ..??JUST WONDERING ...thanks in advance
Save
#26 ·
Sorry guys, it has been crazy with finals this week, been studying like crazy. Here is a brief overview on how to do datalogging with forscan on android, I will do a better job once finals are done.
Step one: follow the previous android forscan how to to connect to your vehicle.
Step 2: Click on "Table"
Step 3: Click on the settings gear to pick PID's to monitor
Step 4: Once you have picked PID's click play to start streaming data.
At the bottom of the screen I have circled the buttons that let you play data forwards and backwords. This is the datalogging portion.
That is the basics of it, I will do a much better one soon, but since I have school, for now that works....
Save
#28 ·
thanks scoutcamper..very appreciated thanku
Save
Status
