Felpros and O rings vs OEM and O rings
9K views 31 replies 8 participants last post by  Hartwig
found a found people claiming the Fel Pros and O rings were going strong but most with low mileage, just wondering if anyone has any recent input on how theyre holding up? I also read that if O ring protrusion is over .008 then you should not run the felpros due to it cutting through the fel pro fire ring surface. Just hoping for some more input here as i will be sealing my engine up pretty quick here
#28 ·
So far, the OE or Mahle have been fine with any of the o-ringed heads from several sources. That would be my safe position.
owns 2003 Ford F-350 Lariet
