I'm going to get into asking a couple quetions?
1. Will removing/disabling/turning offf, etc reduce the dirtyness of the oil? As it stands now, my oil is pitch black after a couple miles.
2. What are your thoughts on the EGR delete, i.e. Remove cooler and EGR and use block off plate, or use blocknoff plate with pass-through, or just disable the EGR?
3. If using block off plates, what are your MFG suggestions?
4. Does removing the EGR system require a tuner or can it just be removed and press on with life?
5. Lastly but off topic, I need to replace my air filter. Don't want to modify the intake. Don't want an oiled filter. Your suggestions?
I do not mind the DEF and DPF system. I can live with the small amount of money for clean urine and loss of MPG during regen. So I won't be messing with this until I become rich and my warranty is over. I just don't like the whole EGR idea. This is for a 2017 F250 XLT, 6.7L diesel, of course. Current mileage 22K.
I have read other threads. Was thinking of the S&B non oiled filter. EGR-wise, was thinking of the GDP with pass-through. If you have another filter suggestion, MFG and P/N would be helpful.
Thanks,
Barry
Thanks,
Barry
