The EGR system is really not doing the engine any favors. The fact that it's recirculating exhaust gases back into the engines intake is the sin. It's hot engine exhaust that is routed through the EGR cooler which at that is 195-200* at best being introduced with the air from intercooler.
It's basically a buzz kill for everything attempting to cool the air before it's in the combustion chamber for the added power from more expansion pressures from the actual combustion. Basically cold air coming into engine expands more from the combustion itself then if it's hotter air temps.
The other downfall is of coarse the soot and snot that is now being pumped into your intake. That alone can build up carbon in the intake and porting of the heads. It can reduce the flow of intake air to a degree from coking up over time.
It's better to not have the EGR system on the engine and that's a well known fact. If you have no emmision testing there it's a good system to kick to the curb.
If you have to run the EGR system using a good fuel additive like diesel kleen or the Ford stuff raises the cetane levels enough to actually help keep the intake and EGR valve much cleaner. I can attest to that being true from my own experience with my first 6.0 that I had the EGR system in it.
Its a system that is better gone if you have no emission testing to deal with. That said the states are coming on line with EPA endorsed smog testing on the diesel powered engines. That is only going to become more rigid as time goes by. Your not going to have any seat of your pants power gains from removing it. But the engine will be more healthy without it.
Decisions decisions.................Tree Hugger or Tree Logger.
