I am a mechanic and struggling to figure out this problem with a 2012 f350 6.7 4x4 truck I am working on. The truck automatically engages the locker when turned on. It's a base module with a switch that only turns the locker on, it's a floor shifted 4x4 model. I am getting two codes. U3000-49, which reads control module internal electrical failure, as well as P189A-00, Axel disconnect input switch circuit low. A new, used, switch has been installed and nothing changed. The locker is disengaging when the truck is turned off as confirmed by spinning the wheels when raised. Anyone run into this problem? New TCCM at this point? I'm assuming it will need a reflash at the dealership as my Snap-On reader cannot perform this function.
