So I finally got my tuck back together and running this weekend after having it torn apart for over a week doing an EGR delete, oil cooler swap, and tracking down an HPOP leak which turned out to be the STC fitting.
I got it fired up, and it ran great!!
BUT....now, just when I think I'm out of the woods with this thing...it's having another issue. A couple times over the weekend after I would fire the truck up, I noticed it had ZERO power.....just about nothing there, and even with the pedal to the floor, it was making ZERO boost. The couple times that it did this, it might have done it for 30 seconds, up to a few minutes.......and then all of a sudden, it was like someone flipped a switch and the turbo spooled up and come to life, and the next thing you know it's making 28psi of boost and pulling like it should.
After every time I had that no boost issue, after I got home I scanned the PCM and found a P0299 "turbo underboost" code.
Does this sound like a sticky unison ring, a VGT solenoid issue, or maybe something going on with the EGR valve? (I did the delete, but left the valve plugged in and in the intake)? Could it be a wiring issue? The plug going to the VGT solenoid looks pretty crummy, along with the wiring going to it.
Later tonight it started doing again at my house, and I never did get it to make boost....I was so frustrated, I just parked it in the shop.
Just looking for ideas here, and where to start my troubleshooting!!
