Do I really need to change the fuel filter as often as it says?
37K views 44 replies 24 participants last post by  mohead1
We don't do this often with out 7.3's. Do I really need to so often with the 6.4? If so Why?
#6 · (Edited)
The 6.4 is miles away from the 7.3, dontchya think?
Guess it depends on what you are counting. Yes the 6.4 motor makes more power with less mods (from the factory). However, the 7.3 is more dependable, gets better fuel economy, requires less fuel system maintenance, and if it were appropriately equipped from the factory would make as much power as any 6.4 on the market.
#3 ·
My god yes, you have too! There are people on here much more wiser than me that can elaberate on it but the 7.3 fuel system is much more forgiving with things like water and dirt in the fuel than the high pressure fuel system in the 6.4.
#5 ·
When you're pushing fuel at 20,000 + PSI for through the injectors, you need the cleanest water-free fuel possible.
I honestly would do the fuel filters in a 6.4 every 5k miles. Its just not worth it when you have to replace injector nozzles and CP3 pumps and even entire fuel systems due to crap fuel and fuel system maintenance neglect.
Or you can just get rid of the crap HFCM that never belonged on these trucks from the get go and replace it with an AD II for better lower micron rated filtration, and far superior water and air separation.
The 6.4s are nothing like a 7.3 or cummins where you can run diarrhea straight from the toilet through the fuel system and it would still run, it just wont happen. I swear these newer trucks sip liquid gold, or so it seems :thumb::thumb:
Now a days off road and on road are the same except for Dye, but it depends, some people can get higher sulfur content fuels, i guess it depends what part of the country you're in. a Buddy of mine ran red fuel in his 6.4 deleted and it want a problem, but that was only because it was worst case scenario on the job (septic excavating company)
#28 ·
When I bought my diesel I was under the impression that they were low worries low maintenance truck, boy was I wrong
#10 ·
Sinner:
It's great having the advise on the site from a profession mechanic. I'm getting ready to take my truck in for it's second service (10k miles) and am definitely going to be following your advise and get the fuel filters changed also.
Thanks for the advise you give us!
#17 ·
but running farm trucks on road is illegal no?
also $10 for a fuel filter? I sure hope youre using OEM filters and changing BOTH fuel filters frame rail and engine bay
this is why trucks get bad raps... improper maintenance, use OEM filters and stick to the change intervals.
#27 ·
Change both filters every 10k or replace the fuel system. Drain the water separator every month or more frequently. Clean the rail filter housing too. I've seen pictures of goo in the housing.
#34 ·
I'll get bashed for saying this, but I got distracted and by the time I remembered, it was at 25K before I changed out my filters for the first time. They didn't look terribly dirty. On the other hand, as long as I've tried draining fuel in the past 2yrs I've had the rig, I've never gotten any water either.
Other than a a few months of truck stop fuel, I've been using Shell and Chevron fuel exclusively--I've never skimped in that regard...
so far, knocking on wood, no issues..
#43 ·
There are a bunch of children hanging around here, thats why you fear bashing.
A dirty filter does not pass dirt unless there is a bypass around the filter. The classic symptom of a plugged fuel filter is that the engine quits running or is low on power due to fuel starvation.
By the same method, a dirty air filter does not let dirt into your engine.
Automotive oil filters usually have a built-in bypass which can flush the trapped crap back into the engine if activated.
#35 ·
pizza pig Quote:
Originally Posted by n4hhe
20,000 is the specified service interval.
and thats a complete JOKE..... every 10k BOTH fuel filter change or you WILL be replacing fuel system components... they'll drop like flies
:agree:!!!!!!!!!!!!!!
#39 ·
My bad. I took your comment wrong. I did get a lawyer last year and Ford actually has offered up a few bills but we turned it down cause it was a slap im my face as far as we were concerned. A lot of time amd my money was spent for alternative transportation, down payment, $1200 monthly payments, etc.
#42 ·
If you are worried about fuel issues, than I would put an airdog 2 on your truck. The water separator on these trucks is trash. Doesnt work worth a damn, is hard to change the filter, and the filter housing is poorly designed. I am putting an airdog 2 on my truck this weekend. I will report back later just how much more water the airdog takes out of the fuel compared to the stock system. Everytime I drain my water separator I get little to no water in the fuel. I find this very hard to believe so thats why I put an airdog on the truck.
