I did my own efuel system with regulated return and I’ve had two Bosch 044 pumps fail within a year and a half. The first one after further research was a knock off, but the second one that recently failed is a genuine Bosch 044 pump. I’m not understanding why they are failing. I have a sump in my rear tank which is a f26e 38 gal tank. Which feeds to my prefilter which is a wix 33405 (14 micron) thru my pump and then thru my post filter which is a wix 33528 (2 micron). I don’t know if my prefilter is to small of micron causing the pump to work to hard to pull the fuel thru the prefilter or what. I know fuel pumps are better at pushing than pulling. Any input or thoughts would be appreciated. Thanks, Jeff
