21 - 40 of 52 Posts
Discussion starter · #21 ·
Hi, yes I put new ones and it didn't change a thing.
thanks.
Well i didnt ask if you have new ones, you need to test continuity to make sure power is getting to the GPs and GPR
Discussion starter · #23 ·
Apologies, yes checked and yes power going through. Also I should mention it throws out a lot of black smoke when it starts.
Im sorry if i sound frank but did you actually test the draw with a volt meter from each side of the poles of the relay not just whether your getting power or not. Read the link i put in the post about glow plugs above it tells you exactly how to test it.
As for the black smoke that means theres excess fuel thats not being burned. If both the GPs and GPR in fact do test good and get continuity then i would look at your charging system. A bad alternator can cause your batteries to not be charged enough to allow the truck to start at colder temps
So I have gone down you list. I picked up a 95 PSD 5-speed not running. I've been trying to get it started for a while now. I have gone down your list. Batteries....good. Fuses...good. CPS...good. ICP....not tried yet (just figured out you didnt mean IPR). GPR - does this setup even matter for a No start issue? I would think it would start either way. IDM...good. fuel pressure... good. I have not looked at the harness or IPR yet. hpop level stays up. I have auto enginuity, but it dont wanna work on this 95, so I have not been able to get any codes. Thoughts? Great write up;-)
Discussion starter · #26 ·
Well you need to get the all important oil pressure and fuel pressure. Short of electrical those are the 2 main killers of starting. You said fuel pressure is good, so im gonna lean towards oil pressure somewhere. Unplug the ICP, and if it starts like that then it could just be the ICP sensor. If it still doesnt start you need to find a way to get oil pressure manually if your AE wont connect. Yours may be a E95 so it just has a dummy OBD port
I unplugged the ICP and it still didnt start. I changed out the ICP with a known good one as well, and it still didnt start. When I pulled the ICO out, there was no oil pressure in the oil rails. Normally when you pull a plug or sensor out of the oil rail.....oil will run out. no such thing on this motor. So I am thinking somehow this thing either dousnt have enough oil pressure, or isnt getting oil period to the rail. When I crank the motor over the oil pressure gauge in the cab goes up, but it takes a while of cranking. I have checked the HPOP resivor several times and its always full accept after it sits for a long time. I wonder if i should change out the LPOP.
Discussion starter · #28 ·
Then your ICP should be good and means you may have problems down the line like HPOP pressure or IPR not opening correctly, thats why you need to test oil pressure because HPOP is a costly en devour to do unless your for sure its bad. As for the oil pressure no there wont be any oil pressure in the rail...the truck isnt running right? And no oil would come out because its higher than the resting level of oil so it wouldnt drain out. The oil pressure gauge on the dash means absolutely nothing, all it is is a pressure switch that pops up to center when it sees at least 2 or 3 psi IIRC. As for the level of oil in the HPOP as long as its to the top the LPOP is working, after a long time its normal to get some drain back.
I took the ICP out of my running 01 superduty and when I pulled it, oil ran out of the oil rail until I installed the ICP I was testing. Thats why I fugured there should be some pressure in the rails. I have had the truck running on either a bit with GPR unplugged. Now I know oil is most likely the issue. that being said. Can I just put a guage on the hpop resivor and see how much pressure builds up? Of do I need to have the truck plugged into a scanner that will tell me oil pressure? I do have another supposedly good hpop/ipr for the truck I could try.
Discussion starter · #30 ·
It may have been residual oil running out, was it running recently? After some time it will all drain back to the pan. But if its running with ether then it means that your injectors are not firing correctly(no necessarily oil related but most likely) but i would not use ether even with the GPR unplugged it still can do some bad stuff to the engine. Yes you can buy a gauge and run it directly off the oil rails(not HPOP) but it will cost a bit, but if you cant get a scanner to read then its your only option to get HPOP pressure.
Discussion starter · #32 ·
I got my AE scanner to work. It dousnt always want to work on this truck for some reason. I have attached a graph of the data. All info is of the ICP sensor. Pressure never goes above 160psi and 50% duty cycle.
Yea im gonna say with that you need a new hpop. What that data is saying is the IPR is trying to close as far as it can to up the pressure of the oil but its only getting 160 psi outta the HPOP so thats wont allow the truck to fire. I say swap it out with the one you got and try to start her up
I installed the other used "good" hpop with IPR. Still no start. New graph of AE results. Any ideas? I dont think both hpop pumps are bad.. they could have been though. I bought them from members who said they came from a running truck. This thing is kicking my ***. maybe I should grab my uncles snap-on scanner and see if that comes up with any codes?
Discussion starter · #34 ·
Yea that's strange...are you sure the HPOP reservoir stays filled? The only thing I can think that would cause that if not a bad HPOP is a bad LPOP not filling the reservoir
I have checked the hpop resivor several times. It is always full. accept after it sits a week or more. The second hpop made 100psi more pressure than the first. I am thinking maybe both hpop's I got were actually junk. I dont really want to buy a new pump. but pretty soon if I have to buy another used hpop or 3 I'll be at the cost of a new one.
Discussion starter · #37 ·
I am thinking of buying this pump: HPOP-004X Ford Diesel Powerstroke High Pressure Oil Pump | ForDiesels.com. Then I would know the pump is good. Thoughts?
It looks like a good price but ive never heard of that site or have any experience with them, i know most guys upgrade to a t500 terminator HPOP when theirs goes out, problem with that is looks like theres a 2-3 week lead time unless you send them a core which you actually have 2 of so that may be a good option if you can wait a bit longer. The advantage of this is it leaves room for upgrades in the future or just runs your injectors a bit more efficiently.
21 - 40 of 52 Posts
