Degas tank pressure testing video
1 reading
8.4K views 51 replies 8 participants last post by  El Gallo
Hey guys. I’m getting some coolant out of my degas tank. It's Nothing like before I bulletproofed the truck, but still comes out. I put a pressure test on it and psi climbs slowly from 0-15 before I dump it. the rise seems to slowdown when I'm up at operating temp. Then, When I hit the gas to about 2500-3000 rpm it actually drops slightly, then comes up about 2 psi when I take my foot off the gas. Why am I building so much pressure at idle? I took a video but am not allowed to post it. Thanks in advance.
Sent from my iPad using Tapatalk
#4 · (Edited)
Thermal expansion and maybe too full of coolant
The cap reliefs at 16psi
Once warm(not hot) and you relief the pressure, does it re-build to 16 within a few minutes?
Normal for the pressure to drop as you rev the engine, ...the degas bottle is on the heater return, that goes to the suction side of the water pump
#6 ·
Sounds like it's headgaskets time...
-jokester
Reactions: john galt and Hydro
#7 ·
Jokester I know that’s definitely a strong possibility, however, I am reading everywhere that with a head gasket failure, pressure in degas goes up under load. Mine actually maintains current pressure and even drops slightly under load and increases with my foot off of the gas. Will a blown head gasket do that as well?
#8 ·
hit an incline and push it WOT I bet it will spike the psi
other than that i cannot figure a way for PSI to climb in the cooling system once the coolant reaches temp ( unless it boils)
i have been monitoring psi and a bad HG for a while I also can see a drop in PSI when letting off the throttle but attribute that to the gasket letting pressure bleed off into the cylinder
the suction side of the water pump should not be able to "suck off PSI in a closed system in my non fluid dynamic professional opinion "
#10 ·
Here ya go
Reactions: mudpuppi
#9 ·
Thanks so much for your help. I’ll drive it through the winter and park it when it gets wArm and turn my garage/ driveway into a disaster again. At least now I know from the first time.
I see shops do cab off. I can probably run an I beam across my garage to do it. I swore to myself that If this happened, I’d never work with the engine in the truck again. Any other way to get the engine out or at least get more access to the back without taking the cab off? Thanks for all of the replies. You guys have really helped my “please don’t be head gasket please don’t be head gasket, why did I take that shortcut” thought process.
#20 ·
I pull out the fender wells, put the frame on 12 ton jack stands back behind the doors, and pull the front wheels off. I have an extra long armed crane jack (I modified mine by extending the arm as far as I could and drilling extra holes for the pin) and load leveller. I pull the left side motor mount and lower that side of the engine to get more room for the right side head. Pull the CAC tubes and air cleaner before doing this, and replace them after the motor mount is reinstalled.
#11 · (Edited)
thanks for posting that
but I honestly don't think that multi-tank and pipe sytem correlates to the automotive system we have here, and it would suggest that while the pump is running( all the time in our case) it would read different PSI depending on where the sender was located but that is not the case with a typical engine cooling system and normally you will see no PSI drop on a healthy automotive cooling system when letting off the accelerator in my experience anyway
please note
Automotive Water pumps are not positive displacement pumps. The water pump is a centrifugal pump that can move a large volume of coolant without increasing the pressure of the coolant. The pump pulls coolant in at the center of the impeller. Centrifugal force throws the coolant outward so that it is discharged at the impeller tips.
#12 ·
The OP vid shows a pressure drop at higher pump speeds, that is normal and expected. Even in a 'hard' piped system this will occur. There only needs to be a small amount of fluid displacement to show on the gauge.
The vid I shared illustrates why the degas bottle is placed on the suction side of the automotive system. The pump in the vid is oversized for the piping to exaggerate the effect.
The pressure drops in the automotive system because of expansion of the hoses and plastic parts, the degas bottle is located on the suction side of the system and serves as a pressurized reservoir.
Cavitation of the water pump can be caused by not having enough pressure in the degas bottle(as seen on the 6.4) or too soft of hoses(lowering the pressure)
Reactions: Patriot
#14 ·
0 psi is what I see
I have an aluminum degas that uses a traditional flip style cap and an overflow bottle
I run a o psi cap.
When I was monitoring psi. They readings would spike in hill climbs. And on easy but long uphill elevation changes
If I ran any tick or not find. The psi went to 16. Right away
I am still gathering parts for my HG,s
#15 ·
Any reason why my ect and eot deltas are not going crazy? Ect is 190/192 eot will reach 198 max on a 75 mile hilly daily one way drive. I figured excess pressure would make these numbers fluctuate a bit more due to constant pressure build and release.
#23 ·
for discussion sake,
i don't think a compression test will divulge the offending cylinder info
normal cranking cylinder psi does not get the HG to the point of leaking on a typical ( underload coolant psi issue)
and the leak is typically so small it wouldn't drop the cylinder psi enough to show up more than a normal variance
and if it was bad enough it would blow apart the cooling system since the cap could not vent enough
thats my free opinion anyway ;_)
#24 ·
I actually did a compression test when I did the studs the first time to see if I had to go change head gaskets. My pressure climbed quickly and rose to 390 on all cylinders. I did it before and after I studded the truck. Same results. That let me to believe that my head gaskets were fine, so I decided not to change them. Bad idea.
Would a cylinder leakdown test have helped?
I already bought the fittings that I need to tee off of the degas line into the cab. I'll let you guys know how it goes.
Can I use one of the open spots on the obd2 to hook up an electronic pressure sensor to my setup? I honestly haven't researched to see if anyone has done this, but I am assuming people have done it for fuel pressure. That way I could always keep an eye on the degas tank pressure.
#28 ·
Ive had one installed in cab for about a year now. It always starts in the morning at 0 than acorsing to engine temp rises. For the last year the highest ive seen it was 13 untill recently now seems to run at 14 at highway speeds and gets real close to 16 if i push it on a big hill up here in the nh mountains
#31 ·
You guys seem to really know the theory behind coolant expansion. Why would my coolant pressure actually start to drop when my thermostat opens? It always seems to do that around that time.
#35 ·
She’s in!! Did a coolant flush and luckily my deltas dropped to 10 degrees( established ten degrees by pulling 40 bales of hay up quite a few hills at 55 mph for about an hour and a half. She didn’t feel it but it IS a load) now she’s in the garage for a while. Head gasket time. I had to take down a wall to get her to fit, but she’s in. Wish me luck.
#36 ·
:crazy::thumb::eek:
Driver's side removed.
#37 ·
That is some hard work. Do you plan on doing anything inside the engine itself?
#38 ·
It is definitely a challenge. I’m not sure what I’m going to to with the engine yet. I’m doing a ton of research to see what, if anything, I’d like to do to it. Things that would make sense for me.
#39 ·
When you pull the coolant standpipe from the front of the engine to the heater core, make sure the oring seal (3C3Z 9J469 AA) fits nice and tight around the pipe. If not it's real hard to get back in without cutting the seaĺ. If I can't lube it and push it back in by hand in a minute I replace the seal. I've tried pulling it in with the screw a couple of times only to break the oring. A $5 part isn't worth the trouble. It's the pipe that is screwed to the alternator bracket.
