Coolant leak
1 reading
22K views 4 replies 4 participants last post by  mweaver131
Hey all. Just bought a 2017 F350 with 97k miles on it. After driving it a few days I noticed that I am leaking coolant. It is dripping down in front of the oil pan and puddling up pretty good. Traded in my 6.4 for this truck so I am pretty new to the 6.7. Any help would be appreciated.
#4 ·
Primary is most likely rent a pressure tester, it's about a 6hr job for a first timer,
the top radiator hose does not like to be messed with so if some one has climbed or pulled on it may need to replace large green oring (ford sells it dont let them lie to you, you dont have to buy whole hose)
Secondary cooling very rare to have problems
Turbo fitting as mentioned in last post usually drains down bell housing
