Geeze, no pressure here.
I wrote this last night but did not post.
Drilled rotors were born out of autocross for weight reduction. Slots remove gases when the brake pads degas, which is the high-temperature range for the binders and organics in the friction material formulation.
For an average OE friction material across all platforms, the materials are formulated
and processed for a higher temperature range. We would run fade tests on the materials during development and production. You have to be pretty radical to get degassing out of them.
There are different types of fade, BTW. The pedal stays high when you have degassing fade; a film of decomposition gasses prevents the friction material from fully contacting the rotor. This can happen if the material is not processed well enough, and during the initial use of new brakes, you get the gassing that would occur in the ovens for an OE friction product. You can also have this gassing if the organic materials chosen (including the phenolic binder) are not selected due to the cost for the higher heat. You can see this in the aftermarket more often. This situation usually has a long pedal as the friction material is excessively compliant (mushy). Even with OE, you can have this when some brakes are not working correctly, or trailer brakes are not doing their part.
A general guide is when you can smell brakes, the friction material is around 500ÂşF, and when you see smoke, it's around 800ÂşF. Rotors typically run about 100ÂşF hotter than the friction material.
Another is brake fluid boil fade when the pedal goes to the floor. This is the primary reason why the industry got away from metal caliper pistons. Phenolic pistons insulate the brake fluid better, but there is a point.
I could go and see what fade test graphs I have locked away. Right now, it's been a long day; maybe tomorrow.
The cliff notes version is that if you are using a good, proper friction material, consumer and commercial vehicles should not need holes (which do crack) or slots. One issue with slots is you need a stiff, hard friction material to bridge the slot or the friction material wears out quicker due to "slicing" a little bit of the friction material with every pass. Okay on a track. But hard friction material without any compliance results in heat banding and hard spots. And hard spots eventually get you into pulsation and steering wheel shake - the cause being the rotor surfaces not parallel, but transitioning thick to thin. The thick areas are that way because the hardened surface does not wear at the same rate.
This AM, I grabbed some data.
First, if you use a good friction material, you won't fade. Secondarily, in 1997 some of the criteria Ford set down for the upcoming Superduty was to reduce the issues present in the OBS vehicles, which would crack front rotors due to the excessive heat, and reduce the possibility of brake fluid boil. A disc/disc vehicle shares the load better and disc/drum. Brake fluid boil was more of an issue with trucks that used steel pistons in the late 80s to early 90s. But the 1999 to 2004 platforms with the Akebono brakes were the most balanced front to rear and incorporated more extensive thermal solutions for brake fluid boil (that were over the top).
I always try to use assembly line rotors, and within the Ford lineup, that also means not the Motorcraft service line, which my old company makes for Ford. Note the durability test day where at GVW normal highway (open two lane road with traffic lights) the brakes are running around 200ÂşF AT GVW.
You will always have some loss of friction with high temps unless you go with a good quality high metallic, and then cold friction is lower (bell curve of all friction material). If you are fading with OE, there is usually something else going on unless you are exceeding weight or speed. Double speed quadruples energy; speed is logarithmic.
Aftermarket companies reduce costs by not doing the extensive baking done with OE products or the more expensive aftermarket products (those are getting rare). They have you do a "burnishing" after putting on new pads, although it's not as extensive as a "Fade Sequence". You can still have a fade issue the first time you push into a high-stress situation.
