Bed damage repair suggestions?
1.6K views 19 replies 7 participants last post by  TooManyToys
I am looking at purchasing a used 7.3 with 90k miles on it, one owner, all maintenance records accounted for. The aesthetic side of things is not great. Outside of a lot of PDR work required, I cannot find a fix for this. One side the bed rails are bent down, and one side they are bent up. The bed itself is straight. I would like to purchase the vehicle and do a restoration of sorts on it, but, I can't find anyone paint and body world that will touch any of this for less than 4500 bucks which included pulling exterior bed panels and replacing them, along with paint fade and PDR. That seems like a tremendous amount of trouble to go through. Another shop wanted to use some tool to try to bend them back and straighten both sides but wanted nearly 5,000 for that alone. There was a time when I paid 7,000 for a showroom quality paint job on my classic car, but those days have seemingly passed.
Is this bed fixable? The decision for me to buy the truck or not hinges on my ability to find someone in or near San Antonio that has the knowledge or ability to repair it for a reasonable cost that makes the whole truck make sense.
#3 ·
Where I am, GOOD beds are over 4,000, and then I have to paint to match. There are some that are 1200, but they look like they came off trucks that were in rollover accidents. They look like crap. LOL. Everyone is proud of their $hit and I don't have a choice but to accept it. LOL. I would be ok spending a few hundred to get it straight and then slapping a headache rack with diamond plate bed rails over it, personally.
#7 ·
Why on Earth would you pay someone to fix this for you :unsure:
Remove plastic covers, get some pliers and bend metal back to proper orientation, run a wire wheel over rusted parts followed by some 220 grit sandpaper, wipe parts with microfiber cloth then spray with self etching primer 2-3 coats then spray paint colour of choice. While plastic covers are off you can spray with brake clean and then paint with black trim spray paint. 4-5 hours worth of work and $60 tops for supplies.
#16 ·
To be honest, several body shops didn't want to touch it and I figured if they can't do it, then how am I going to. However, your comment gives me hope. I damaged a body pin on a tailgate a few years ago and had to get a new tailgate on my own truck. The body shops wants to cut, grind, weld, wiggle and jiggle to get it back straight and it wasn't cheap. I ended up using some bar stock and a clamp/wedge to straighten it back out to near 'pre damage' status and it took me less than 45 minutes to do it. I just lose my confidence sometimes.
#9 ·
As long as the sides are not buckled, that should not be that hard to straighten. Work from the sides to the center. Last to bend; first to straighten, a little at a time.
owns 2003 Ford F-350 Lariet
#10 ·
Another option would be to find a Votech, either High School or Community college and let them fix it for the learning experience. Only cost would be for materials. They're always looking for projects to teach students on. All the work is supervised by instructors. You could also try to find an out of work body man that needs to make some extra money. There are several options you could use to get it fixed. Unless the bed is twisted or the exterior body panels buckled, Why not fix it yourself? If you don't have the tools you can always rent them from Equipment Rental places. It doesn't look like it would be that difficult to fix.
#11 ·
To answer y’all’s question? I don’t know how it occurred. The guy that owned it died and I’m thinking of buying it. 90k mile 7.3 so it seemed worth it to consider. From the looks of this, it seems they used the bed rail with a ratchet strap and tore it up. On the other, looks like something heavy was placed in it. The sides are not buckled.
I’d like to buy and restore.
#20 ·
Basically, you have a long dent. There are plenty of videos on YT about how to hammer one out. Some of the paintless dent repair videos can help, too. It will just take a lot of time.
