Well, my OEM exhaust manifolds are leaking and it is slowly getting worse. I plan on removing the OEM exhaust manifolds and putting in manifold gaskets to eliminate the leaks in the next couple of months.
I would prefer to reuse the OEM manifolds to keep the costs down since my wife and I recently found out we are having our third child. :thumb: With that being said, if there is enough of an advantage to replacing them with the BD Diesel manifolds, I would definitely consider it.
So here are my questions:
1. Should I clean up and reuse my OEM manifolds instead of replacing with the BD Diesel manifolds? A lot of reading on the subject suggests the performance gains really aren't there for the $550-$600 investment.
2. What manifold gaskets have people had success with in the past? I know there is an OEM part, but it seems like people have had good luck with the Vincos, CNS and other aftermarket gaskets. They are all very inexpensive, so I would prefer to use what people have actually used and liked.
3. Obviously I will be replacing the fasteners for the exhaust manifolds. Is there a preferred aftermarket alternative, or should I just use OEM fasteners again? They seem to rot out fairly quickly, so I would hesitate to put another set on.
4. Any tips or tricks to make the project go smoothly? I plan on blasting them with penetrating lubricant for a few days prior to starting the project and removing the fender liners. Having a manual transmission means I don't have to worry about the trans dipstick, so that's one less bolt I have to undo. :grin:
Thanks in advance.
Thanks in advance.
