banks Quick-Turbo assembly?
6.7K views 10 replies 5 participants last post by  cletusjermal
is anyone running this on their truck? i emailed banks some questions about it but didnt get the answer i was looking for.
for those of you that are running it, do you notice a difference between this is the stock one? and what is this one made out of?
#2 ·
It's just a stock turbo with a 1.0 exhaust housing and a e99 compressor wheel. There are way better turbos out there for the price.
#4 ·
if you want a 1.0 housing the vendors can get you a 1.0 housing and outlet for around 300.
the banks stuff is way overpriced.
#5 ·
Why do you want aluminum
#6 ·
You will never find an aluminum exhaust housing on a turbo.
The only thing Banks I would ever buy is there Technicooler intercooler.
If you going to go this far with a billet wheel, housing and all the other stuff, by the time to spend the money, you may as well just get a KC Turbo STG1 $1190.
It already has everything you are looking for but with a .84 exh housing and is a bit bigger to grow with a bit larger injectors and has a WARRANTY.
Or you could do the DIY kit for $850
#7 ·
I had one on my truck. I liked it. It had more power then the stock. It was putting out about 25psi. you may be able to tighten the wastgate down a more and get some more boost out of it. I swapped it out with a 38R. The 38R has more lag off the line then the banks it seems like. I am selling it if you are interested. It only has about 20,000 miles on it.
#8 ·
Also you have to take into account your mods. I have the banks 1.0 housing right now. I'm also running 35" tires, 3.73 gear and have a standard. This combo does not work well together.
#9 ·
I'll have 265s on it. It's got 3.73 gears. Not getting lifted or nothing. I might go up to 285s and that's about it. How much are you looking to get for your used one?
#11 ·
#10 ·
If you can hold off a month. I'll see if I can find my old housing. Then I'll sell it off. Cant really do antrhing nkw because its in the truck. If I can't find it we can do some sort of trade. Sound fair?
