Is there a CAT or another equivalent to the Amsoil Oil Bypass EABP100-EA filter?
Sent from my SM-N950U using Tapatalk
Just looking to get something cheaper, if possible. If not, then, it's fine. I'd like to get about 10-20 to keep on the shelf at home. I wasn't sure if anyone already tried to source this out or not.You would need to be sure the threads are the same. Otherwise change the housing adapter to fit the new filter.
I didn't realize that, I thought they were to be exchanged once a year. Maybe I need to review this again. I didn't think about draining it out, either.Those filters could easily go 65k miles from what I gathered in all my research. Not to mention that's about what they recommend for a service interval. Ran the 90 on my 6.0L....I would drain the filter element at every change, then replace the filter itself once a year.
10-20 filters....That would be like 900k miles using 15 filters.........
25-30 years... [emoji1787]At the time I was running the Amzoil kit I was easily going 30k+ a year.
Just by 10 filters, get the best price. That will be plenty unless you want to go the full 60k+ on them. Maybe then just buy 5 filters. That would be 25-30 years worth of filtering for you......just sayin'
Will it not go that long??but I want enough for the lifetime of my truck, I don't like having to get one every time I need one.
I've got to start using my rep again, I was getting mine from dealer that sold me the bypass.The Amzoil rep...
You're right, @ $40 year to save injectors, it's easy enough to just replace, even if it does last longer; sure is cheaper than a new set. So, that's what I've been doing.Yea....I did sort of the same thing. I just did it year to year for the most part.
Of all the sales hype over in Azmoil world the by-pass filters are up and up. Plenty of other people testing and using them report the abilities are on point. On a 6.0L the oil filtering is key to a long injector life. So using the by-pass, swapping the filter once a year for the cost was WAY too easy to do. On my oil change intervals I would drop the by-pass filter, let it drain to the pan, then reinstall it. Once a year replace it...done deal.
On most newer trucks there is no oil used for the injectors so I think it's not as big a deal. I would love the Amzoil kit if I could use the OEM main filter instead of their filter.
I meant OEM in place of the Amsoil filter. But, what would the point of that be now that I think of it. The OEM is a 20 micron filter where the Amsoil is a 2 microns, I don't think anyone else is going to offer that level of protection.I would always change the OEM filter at every change. I try to run 7,500 mile intervals at max. If I'm at home and can do it at 5,000 miles I do so.
Remember the Amzoil by-pass filter is filtering a very small amount of oil when the engine is running. I think someone or maybe I did the math for the "flow rate" thru the by-pass filter. The time to filter was something like you needed to run the motor for a few hours to have passed all the oil thru the by-pass filter once. I can't recall specifically.
