Pictures Below
Installing new radiator and discovered the incompatibility of the provided trans line connection method (screw in hose nipple) to the factory line quick connectors. As I look around at the aftermarket availability I see most radiators come with the obligatory screw-in nipple. I contacted the seller and was told they have no offering in the way of adaptors. I really thought I would be able to come up with a way to get these mated up on my own without removing the factory fitting and connecting them with hose and clamps. I would imagine someone has ”sperience” with this exact issue. I want to do it right and solid. Thank you for any advice. Steve
