99 F350 7.3 - Dead Throttle pedal
8 reading
9K views 19 replies 5 participants last post by  dantecaz08
#1 · (Edited)
Hey Everyone,
My favorite truck is driving me nuts. I've had an issue with the throttle pedal going dead. I replaced the entire pedal assembly with the new IVS and TPS about a month ago. Everything was running great.
I'm not sure it's related at all, but I then had someone try to steal my truck by drilling out the ignition switch. They drilled a bit too far, but when I put a replacement ignition switch in, everything started and worked fine (with the exception of I'm getting a B1352 code). I drove the truck several times and everything was great.
Then while driving the throttle just quit responding completely and the SES came on. Limped it home and connected Forscan which shows a P0122 code.
Troubleshooting I've done so far:
  • Tested all fuses, all are good.
  • So while the truck was running I looked at the IVS while hitting the pedal and it is showing "off throttle" correctly.
  • With key on, engine off I tested the yellow wire at the TPS plug. I have a good ground.
  • With key on, engine off I tested the brown wire at the TPS plug. I have a solid 5v.
  • With key on, engine off, I probed the grey wire at the TPS plug and depressed the pedal to see if the voltage changed. The voltage went from ~1v - 3.6v.
The PCM is less than six months old and came from the folks at Chattanooga, so I'm confident it is solid.
What am I missing for troubleshooting steps?
Thanks in advance for any help!
#4 ·
#7 ·
Key ON, without the engine running, as you push the pedal down and let it up again, do you see a clear and even change in TPS value? Does it look consistent and "make sense"?
Right now, if you start the truck, will it drive & rev as it should or does this happen intermittently? (the time to Test is, of course, only when it's acting-up...)
#9 ·
Sounds like a breakdown in communication between the pedal and the PCM to me.
Reactions: MtnTallPaul
#10 ·
O.k., update. Been busy at work so I couldn't get to the truck.
With EOKO using Forscan I see the following:
IVS - Off Idle
TPMODE - PT
TP_F - NO
TP RATE, G - -1.00
With the key on I checked with a meter the connector at the TPS and observed the following:
Brn/Wht - 5v
Yellow/Wht - Grnd
Gry/Wht - When pressing the pedal it changes from .5v to 3.7v.
Assuming there must be something in the wiring I pulled the connector from the PCM and testing continuity between PIN 24 (Yellow/Wht TPS) and the connector at the pedal, and there is continuity. I then tested PIN 89 (Gry/Wht TPS) and the pedal, and there is continuity.
I've tried clearing the P0122 code with Forscan but it just keeps coming back. So clearly there is something wrong, but I am not at all sure where to go from here.
Any ideas?
#11 ·
Well, not just continuity, but rather do you see that the change is the same At the pedal as well as, At the PCM's plug?
Compare the resistance measurement change at the pedal (not voltage, which would require that it's all plugged-in) and what those same wires are showing the going into the PCM. This is a wiring check between the two...
#14 ·
We're only concerned about From the pedal To the PCM because you say you don't see the change in TPS value (that's a resistance value) in ForScan. So, whatever resistance there is in the pedal changing should be reflected in TPS position too.
Off hand, I don't know which wires or where in the plug you will find this change and what those values should be. I would just try the 3 (there's probably a Common, a trigger for the IVS sw, and the other for that resistance change).
You can't hurt anything, put your meter in Ohms measurements, pick 2 wires (pins in the plug going To the pedal) and find the pair that moving the pedal up & down "swings" resistance value.
Go to the PCM plug and find those same 2 wires and see if you get the same readings.
When the PCM wants to increase RPM it sends changes to the IDM (but, again, we want to know why the TPS value that the PCM uses isn't changing with pedal movement - as in your post #8)
#15 ·
O.k, so I found a service manual on another post and I've been going through the troubleshooting for the P0122 code.
One step states:
DD7 CHECK VREF CIRCUIT VOLTAGE  Measure voltage between VREF circuit and ground.  Key off. Was voltage 5 V ± 0.5?
Yes - GO to DD8 .
No - REPAIR open in VREF Circuit 351 (BR/W). RESTORE vehicle. CLEAR DTCs and RETEST.
I have 5V with the Key On, but not with the Key off. So I'm suspecting there could be an open in this circuit?
I can't seem to find any diagrams for where VREF circuit 351 (Brn/Wht) routes so I can check it.
Also seems strange that this is needed with Key off.
#16 ·
No, that 5v (this is what we call the reference voltage that sensors mostly use) is Only going to be found with the key ON. The PCM sends out the 5v, and ya know if the keys off the PCM isn't running, and as that voltage goes thru the potentiometer on the pedal (that variable resistor we're watching to see a change from as the pedal is depressed and released) it "deflects" from 5v (the .5v to 3.7v you saw). That's how the PCM determines how far down you've pushed the pedal.
Can you see Why I want you to measure the resistance change? (not gonna be able to do that with Voltage once it's unplugged from the PCM) and then see if the PCM has that information available At the connector?
This is all because you say that when you're monitoring TPS position in ForScan and depressing the pedal, you don't get a change in the value. Your truck won't "Rev" AND the problem looks like it's because the PCM isn't seeing the pedal being pushed.
So either the PCM has an internal problem reading the pedal OR the information isn't available to it because the wires aren't bringing the information to it because of a connection problem (if it changes At the pedal but Not in the same wires it reads from).
Not sure why you're fighting the method I've laid-out for you.... ;)
#17 ·
Sorry, no fighting at all, I just got excited when I found the detailed testing in the service manual.
So the three wires at the TPS plug are:
Yellow/Wht. - Ground
Brn/Wht - 5v VREF
Gry/Wht - Signal
So I'm assuming with the PCM plug out, you are saying testing the resistance between the Brn/Wht and Gry/Wht as I depress the pedal and see what it reads at the PCM plug?
#18 ·
Again,,, I don't want to guess which two because it's pretty irrelevant ;) I would unplug the pedal and use a meter set to the Ohms scale to find the pair of wires that vary resistance as the pedal is depressed. Take note of those colors and go to the PCM plug and test for a repeat of what you found At the pedal (with the pedal plugged back In of course)
Reread as much of what I've already said if you need, I think I've gone to great lengths to explain it all! ~hehe
