I have a small leak between the drivers side manifold and the up-pipe, enough you can hear it from the cab as an audible ticking. I was wondering the importance of fixing it and temporary ways to fix it before I get into the job of replacing the manifold. as of now i still make plenty enough boost although I'm not sure if its the normal amount as i have a WW2 compressor wheel installed, i use PHP hydra 80hp tune and at WOT it gets between 25psi and 30psi, as well as i get 11MPG, running 4' lift and 33' tires, 5' straight pipe going on 367k miles, attached is a picture of the the ole girl from 2 years ago.
