Does anyone know the size of the exhaust manifold to block bolts?
I believe they are m8 x 1.25 but i do not have the lenghts.
The manifolds are a bit different- one has the bolt head mating surface at about 40mm from the block surface and the other is about 50mm.
So are the bolts same length left and right sides?
How much should or can the bolt thread into the block?
Is 6 point or 12 point recommend?
