I changed the fluid, filter,new gasket, filled it up and the drain plug is leaking. Went to dealer and bought a new drain plug, thinking the gasket on the plug was damaged. Put it in and it's still dripping. Any ideas or do you think I just need a new pan? It threads on correct, not cross threaded, I can put quite a bit of tension onto the bolt so I don't think it is stripped. Lost at what it is...
