Hey all, so I did a 6 inch rough country lift, it comes with a trac bar relocation bracket.
I did an adjustable trac bar but according to the mechanic the trac bar was all the way in, meaning fully closed, but said the front end was a little off by a degree or two.
Took it back to the shop that did the lift and they put the stock one back.
The front end looks good? I guess, do I need an adjustable trac bar? I'd had a relocation bracket specifically to line up the front end.
See photo of it now, does it look okay? Truck drives fine by the way, doesn't weave or swerve any direction, etc.
Appreciate any input
Don't want to blow something up when I put it in 4x4 for the snow cause the axel ain't straight and the driveshaft is sitting sideways from the transfer case.
I guess looking at it now, it's slightly to the passenger side?
