Status
Not open for further replies.
6.4L Powertrain Control/Emissions Diagnosis Service Manual (2008)
45K views 29 replies 12 participants last post by  twolferulz
There is a running joke in the 6.0 section that I am the ORG Librarian. This post won't help that joke to go away, I suspect...
Previously I posted a scanned copy of the 6.0L PC/ED. For those unfamiliar with the PC/ED, I described it like this:
... Anyone who has one of these knows that it's the shiite. For those who do not, I'll describe it briefly.
You know that one time when your brother was really drunk and he told you A) there is a Brake Pressure Applied switch on your 6.0 and B) how to effectively troubleshoot it? That came from the PC/ED.
Remember that other time when your great uncle - on his death bed - told you how to do a KAM reset? That also... well... you get the idea.
Today, I stumbled across a copy of a PC/ED for the 6.4 (2008) in CHM format. I will attach that, but it isn't the most useful thing in the world. As such, I will be posting the relevant sections that I converted to PDF.
Here is a qualification statement with regard to this post:
  • I believe that this document to be of print and able to be posted without issue. If you are overly squeamish in a copyright sense, do not so much as cast your eyes in the direction of these documents.
  • The PC/ED is for the MY2008. Use your brain if your 6.4 is not a MY2008. In fact, use your brain, regardless.
Because the forum only allows (5) attachments per post, this will take a few posts to complete. Be patient. ...and - to keep things together - I'd prefer if posts from others could wait until the last of the Pinpoint Tests go up.
Save
#2 ·
Attached you will find the 6.4L Powertrain Conrol/Emissions Diagnosis Service Manual (2008) in CHM format:
2008 PCED 6.4L Manual.chm
CHM is a specially coded Microsoft Windows Help File file format. Download it to a Windows PC and double-click. The Windows Help System should take over.
For those of you using other operating system (I use Ubuntu), you may or may not have luck opening this. I did not and had to open it in native Windows using VirtualBox.
Also attached are:
2008 64 PCED - Engine Control Components.pdf
2008 64 PCED - Fuel System.pdf
2008 64 PCED - Powertrain Control Hardware.pdf
2008 64 PCED - Powertrain Control Software.pdf
___________________________________________________________
Edited to add...
Well, this sucks. The forum does not allow the attachment of CHM files. I will figure out a Plan B for that one.
Until then... the PDFs will have to do.
Save
#3 ·
Attached you will find the diagnostic procedures for hard start/no start and poor performance conditions (along with their associated worksheets).
2008 64 PCED - Hard Start-No Start Diagnostic Procedure.pdf
2008 64 PCED - Hard Start-No Start Diagnostic Worksheet.pdf
2008 64 PCED - Performance Diagnostic Procedure.pdf
2008 64 PCED - Performance Diagnostic Worksheet.pdf
Save
#4 ·
Here is the most important part of all of it...
Attached is the map between DTCs and Pinpoint Tests:
2008 64 PCED - Diagnostic Trouble Code DTC Charts and Descriptions.pdf
...and the beginning of Pinpoint Tests:
2008 64 PCED - Pinpoint Test AA - PCM Read Only Memory Failure.pdf
2008 64 PCED - Pinpoint Test AB - Engine Oil Level Overfull.pdf
2008 64 PCED - Pinpoint Test AC - OBD Systems Readiness Test Not Complete.pdf
2008 64 PCED - Pinpoint Test AD - PCM Reset.pdf
Save
#5 ·
...and more tests:
2008 64 PCED - Pinpoint Test AE - Unable to Activate Self-Test - Network Comm Error.pdf
2008 64 PCED - Pinpoint Test AF - Glow Plug System.pdf
2008 64 PCED - Pinpoint Test AG - Accelerator Pedal Position Sensor.pdf
2008 64 PCED - Pinpoint Test AH - Cooling Fan.pdf
2008 64 PCED - Pinpoint Test AI - Brake Pedal Position Switch.pdf
Save
#6 ·
...and more tests:
2008 64 PCED - Pinpoint Test AK - Turbocharger Actuator.pdf
2008 64 PCED - Pinpoint Test AL - Transmission Range Circuit.pdf
2008 64 PCED - Pinpoint Test AM - AC Clutch.pdf
2008 64 PCED - Pinpoint Test AN - Power Take-Off Control.pdf
2008 64 PCED - Pinpoint Test A - PCM Power Relay.pdf
(Not sure why the unix ls command put Test A all of the way down here o_O...)
Save
#7 ·
...and more tests:
2008 64 PCED - Pinpoint Test AR - Misfire.pdf
2008 64 PCED - Pinpoint Test AT - ECT and EOT Correlation.pdf
2008 64 PCED - Pinpoint Test AU - MAP and BARO Correlation.pdf
2008 64 PCED - Pinpoint Test AV - MAP and EP Correlation.pdf
2008 64 PCED - Pinpoint Test AW - IAT and IAT2 Correlation.pdf
Save
#8 ·
...and more tests:
2008 64 PCED - Pinpoint Test AX - Intake Throttle.pdf
2008 64 PCED - Pinpoint Test AY - Brake Pressure Applied Switch.pdf
2008 64 PCED - Pinpoint Test AZ - EGR Cooler System.pdf
2008 64 PCED - Pinpoint Test B - Reference Voltage VREF.pdf
2008 64 PCED - Pinpoint Test C - Clutch Pedal Position CPP Switch.pdf
Save
#9 ·
...and more tests:
2008 64 PCED - Pinpoint Test D - Crankshaft Position CKP Sensor.pdf
2008 64 PCED - Pinpoint Test DF - Vehicle Speed Sensor VSS.pdf
2008 64 PCED - Pinpoint Test E - MAP Sensor.pdf
2008 64 PCED - Pinpoint Test F - Intake Air Temperature IAT Sensor.pdf
2008 64 PCED - Pinpoint Test G - Intake Air Temperature 2 IAT2 Sensor.pdf
Save
#10 ·
...and more tests:
2008 64 PCED - Pinpoint Test I - Parking Brake Applied PBA Switch.pdf
2008 64 PCED - Pinpoint Test J - MAF Sensor.pdf
2008 64 PCED - Pinpoint Test KA - Turbocharger System Performance.pdf
2008 64 PCED - Pinpoint Test K - ECT Sensor.pdf
2008 64 PCED - Pinpoint Test L - EOT Sensor.pdf
Save
#11 ·
...and more tests:
2008 64 PCED - Pinpoint Test MA - Fuel Pump Control - Low Pressure Pump.pdf
2008 64 PCED - Pinpoint Test MB - Fuel Rail Pressure FRP Sensor.pdf
2008 64 PCED - Pinpoint Test MC - Fuel Rail Temperature FRT Sensor.pdf
2008 64 PCED - Pinpoint Test MD - Fuel Cooling Pump System.pdf
2008 64 PCED - Pinpoint Test ME - Fuel Pump Control - High Pressure Fuel Injection Pump.pdf
(This is turning into a complete pain in the butt. Seriously... if I didn't feel sympathy for 6.4 owners. Lol.)
Save
#12 ·
...and more tests:
2008 64 PCED - Pinpoint Test M - Fuel System.pdf
2008 64 PCED - Pinpoint Test O - Water In Fuel WIF Sensor.pdf
2008 64 PCED - Pinpoint Test P - Fuel Injector.pdf
2008 64 PCED - Pinpoint Test QH - Fuel Level Input.pdf
2008 64 PCED - Pinpoint Test RA - Catalyst System.pdf
Save
#13 ·
...and more tests:
2008 64 PCED - Pinpoint Test RB - Diesel Particulate FIlter DPF System.pdf
2008 64 PCED - Pinpoint Test RC - Exhaust Gas Temperature EGT Sensor.pdf
2008 64 PCED - Pinpoint Test V - Camshaft Position CMP Sensor.pdf
2008 64 PCED - Pinpoint Test WA - EGR Temperature EGRT Sensor.pdf
2008 64 PCED - Pinpoint Test W - EGR System.pdf
(Clarification: I only sympathize with you because - every time I look at documentation - I realize again how complicated of at vehicle it is. ...and then there is that 20lbs of shiite in a 10lb bag thing going on under the hood. Cool trucks, though!)
Save
#14 ·
...and the last tests:
2008 64 PCED - Pinpoint Test X - Exhaust Pressure EP Sensor.pdf
2008 64 PCED - Pinpoint Test Z - Keep Alive Power.pdf
Save
#15 ·
While we are at it... Electrical diagrams and a couple of odd stray documents that may be of interest.
That is it. Enjoy.
Save
#16 ·
It turns out that the forum allows ZIP attachments. I did not know that. I guess that I never scrolled that far down the compatible files list.
...so here is the PC/ED CHM file zipped:
2008 PCED 6.4L Manual.chm.zip
It's cool to be able to use the PC/ED that way, if it works.
Save
#18 ·
Thanks for the thanks. Given that there was absolutely no response to this thread after I posted it, I figured that the 6.4 crowd was all wallet and no wrench. Glad to help a fellow DIYer.
Save
#19 ·
Wish I would have seen this 2 months ago... Made the thread slightly more accessible/find-able for people :thumb:
Reactions: djmaguire
Save
#20 ·
Thanks for stickifying it, @CrazyS0b . That'll help visibility immensely, yes!
I think PC/EDs are way helpful. Even though I don't have a 6.4, when I saw it, I couldn't pass up sharing.
Reactions: CrazyS0b
Save
#22 ·
Hi djmaguire, I tried to download the service manual you posted and i cant get it to download. It keeps sending me to windows help. Is there a trick or is the file no longer any good? Thank you for all the help. Any help with figuring out how to use the file would be greatly appreciated.
Thanks again!!
#23 ·
Sorry for the huge delay. I only just saw this.
I assume that you are referring to the ZIP file. I just downloaded it to my phone and it worked fine. You might try a different device or install WinZip first.
Reactions: gwl24651
Save
#25 ·
I'm a newbie, got a 2008 F350 Dually, four-door, w/6.4, and don't know anything about diesel's other than I love the truck!!! I've built cars, hot rods, and trucks all my life (64 yrs old) engines, transmissions, rear ends, paint, bodywork...the whole nine-yards and from the bare chassis up...but I know ABSOLUTELY nothing about diesel's and admit I'm a real dummy about them. I think you're really an incredible dude for sharing all this info. on-line.
I'm having some "power under load" problems (just loses all pedal response) I've noticed as well as a really loud "roaring" that something under the hood is making (sometimes/most of the time) while just driving along, so loud it's hard to talk...had one guy (said he was a diesel mechanic) say it was just the fans...if so, man they get really loud. My old 2001 F350 w7.3 never sounded this way. I hope some of this info will help me out.
I actually own a printing company so it's easy for me to print out!! Again, THANKS, your the best for doing this!!
Status
