I replaced my actuator on my 6.4 which failed and it set off code P132b and P2263, after checking all the sensors it was recognized as the actuator. I discconected the dogbone connector and when you did the KOEO mode it did move but grind. My actuator had a cooling pod bolted to it and the plug for the electrical. I checked the new dog bone type connector to the old and they both matched in length and distance. If you try to turn it, it takes a lot to turn either one, so I am thinking that they come from the factory set. I DID NOT TURN the end eyelet. I cleared the codes and the truck and actuator work well. Does anyone know if there is additional calibration needed?
