@puna.skeeter
If you have a 06 turbo you need the 05-07 turbo pedestal and then it will bolt right up to your 2004.
"There were 3 different turbine wheels offered in the 6.0 powerstroke gt3782va turbo. Over the years ford attempted to do 2 things while changing the turbo specs... quicker spool and quieter turbo. Those were two big complaints early on. So they first changed to a 13 bladed turbine in 2004 that kept a very similar 72.5x66mm dimension. Then sometime in 2005 ford changed to a 72.5x64mm turbine to increase spool up. So over the years the turbos lost top end power, increased spool up, and got quieter.
2003-2004 10 blade 72.5x66 10 blade turbine (basically a small gt40 turbine)
2004-2005 13 blade 72.5x66 13 blade turbine (larger 13 blade)
2005 - 2007 13 blade 72.5 x 64 13 blade turbine (smaller 13 blade)
There were also 2 different compressor wheels offered. As the turbine wheels got smaller... so did the compressor wheel. This provided even quicker spool up, but sacrificed top end power in the aftermarket performance world.
2003-2004.5 - 59x82mm
2005-2007 - 56x82mm"
All above from a forum member.
