Hi everyone,
My dad is looking to purchase a 2004 F-250 with 146k miles, but it has a pretty large oil leak dripping down the back of the engine upon startup...like a continuous stream which will quickly make a puddle. The leak goes away once you start driving, but it will pour out again if you shut it off and then start it back up.
I took a FORScan datalog while driving it around and the ICP values looked good (nearly 3700 psi at WOT) and the IPR duty cycle percentages did as well. I'm guessing the leak is coming from a bad o-ring on one of the HPOP output lines? Maybe once it builds enough pressure, it pushes the o-ring into place to sufficiently seal??
If it is something simple like replacing a line or o-ring, he would definitely pull the trigger on buying it.
Any help would be appreciated.
Thanks!
(datalog attached in the ZIP file as FORScan file and CSV if anyone is interested)
Thanks!
