I have a 2004 6.0 that is blowing white smoke all the time. problems started about a week and a half ago after i went to a different gas station than normal. it started to run rough with no power from a stop but as it got up past 15-20 it started picking up. after i ran through that gas and refilled at my normal gas station the loss of power stopped and now it always blows white smoke, and a lot of it too. the ficm manually tests good with 48.7 volts on pin key on, 48 flat during crank and 48 running. i pulled the egr valve and i had a broken o-ring, i replaced that and cleaned the egr with no change in smoke. brand new fuel filters. im not loosing coolant at all either. no engine codes as well. i have my daughter due any day now and i need some help!! this is our daily driver.:crying::crying:
