6.0 belt driven air compressor
5.2K views 8 replies 4 participants last post by  Heavy_GD
Hi all,
I am interested in installing a belt driven air compressor on my 05 6.0.
I have been looking into buying a used Bendix 550 (yes, I know it's overkill) off an International VT365. Theoretically it should mount up with the provided bracket.
The compressor needs engine oil and coolant to work. I was wondering where I would go to tap into an engine oil supply, and where to drain it into. Same goes for the coolant supply.
Compressor will be used for a train horn and air suspension. Don't really want an electric one mainly because of the electrical load, and they don't flow as much as an engine driven one.
Thanks.
#6 ·
I gotta tear into the engine to do egr and oil cooler soon-ish so I dont think it would be too much of a hassle to stick this in.
Any ideas where to tap into for oil supply?
#9 ·
to Z's point, how much oil do you need?
You could just run a by pass filter set up and tap it from there.
But if you need that oil to be under pressure thats a different convo.
#8 ·
What are you powering off the compressor?
