When I had the add-a-leaf/hanger lift I didn't get the dropped pitman arm in the kit at the same time. After some research I extended my drag link to minimum safe thread engagement (I forgot that number) and my steering wheel was still tilted (stooped word filter doesn't like the work cauked) to the right. Once the pitman arm was swapped, all was good.
The track bar swings in an arc, the leafs want to move straight up and down. The leafs will twist to maintain axle pad angle, but they physically can't move side to side enough to match a longer track bar. Sooner or later, the leafs and the track bar will bind. This is probably why the Super Duty went coils in 2005 and never looked back.
Ours is one of few vehicles that uses leaf springs with a track bar. Normally, track bars are only used on coil suspensions (called a panhard bar) to prevent side to side movement, such as in cornering.
For best results, keep the drag link and track bar at the same angle. If you use a drop bracket on one, use a matching drop bracket on the other. If using a longer track bar, then you need to have that much length available in your drag link adjustment.
