I saw a YouTube video recently, where the poster was saying there are some big issues with the '20+ Super Dutys. The poster was claiming that the CP4 was weak and could fail (but that could potentially be fixed prior to failure). The two things he listed that were most alarming to me were the Transmission and the Engine Brake. The new 10 speed only has a year under its belt in the Super Duty. Yhe poster claimed that he had had 2 F350s so far that both when they reached the 50k-60k mark started experiencing hard shifting and making noises. The poster has a shipping/hauling company. Perhaps the poster was really pushing his trucks too hard.
Now the Engine/Exhaust brake is a big issue especially if you are towing really heavy loads. I have had limited use of the system on my 19 F450 when towing no more than 7000lbs including the trailer. What the poster says the problem is that the truck can over rev by aggressively downshifting, and that I can attest to. I had that happen twice when towing, the system in the passive mode, it aggressively downshifted and I found my truck quickly heading for the red, I took it out of tow hail and turned off the engine brake and moved trans to manual to bring the trans back to 4th or 5th and then just use the trucks brakes.
I got to say that I miss my 14 F350, the truck had the first gen of the engine/exhaust brake, just no way from the factory to use it. I ended up getting an aftermarket module that allowed access to it. In passive mode it would just downshift, but in active mode it downshited and shut the vanes on the turbo, and that helped stop the truck towing 14000lbs very quickly and didn't even get close to redline because it utilized the exhaust brake function of the system.
With that being said, it was stated in the video that even in active mode on the 20+ trucks, the system just aggressively downshifts.
I'm looking to see if anyone with the 20+ trucks have seen any of these issues, or if they hold any water. I am looking to get a F550 cab chassis sometime this year and it will be used primarily to haul trailers long distances and through mountains. So I need to know if it will be reliable.
