2013 F-550 6.7L No Crank
1.4K views 3 replies 2 participants last post by  PSak96ss
Looking for some ideas where to begin - I'm waiting on shipment of the paper copy of the factory wiring diagrams to arrive, but in the meantime...
I have a 2013 F-550 6.7L, which is underneath a 2014 Thor Chateau Super C. Got in to pull the camper up so I could do trip prep, and it won't crank. I checked the batteries, 12.5 and 12.6 volts individually, and on my load tester they are both still good.
I get a glow plug light, but when I turn the key to START, nothing - HVAC fan turns off briefly, then back on. Frankly, I can't remember if the tach/speedo are supposed to sweep or not, but they don't.
FORScan shows the following codes:
PCM U0212 - Lost Communication with Steering Column Control Module
PCM U0140 - Lost Communication with Body Control Module
PCM U0155 - Lost Communication with Instrument Panel Cluster (IPC) Control Module
BdyCM U0100 - Lost Communication with ECM/PCM
BdyCM B1310 - Run/Start Control
IPC U0100 - Lost Communication with ECM/PCM
IPC U0101 - Lost Communication with TCM
IPC U0121 - Lost Communication with Anti-Lock Brake System (ABS) Control Module
ABS U0140 - Lost Communication with BCM
TBC U0100 - Lost Communication with PCM
TBC U0121 - Lost Communication with ABS Control Module
So, clearly there is a wiring issue. It had been sitting on a battery tender, no issues starting prior to this, I could just jump in and it would start right up, but now that I want to move it... ;)
We had an issue on a previous trip, on the interstate, the gauges and HVAC stopped working. Appeared to be whatever that harness issue is in the footwell next to the parking brake. That was fun while we were driving. I was able to jiggle the harness around and get it all to work, drove home with no further issues, but then I could never replicate the issue to fix it - I'm leaning towards that's where I should start looking, but nothing is leaping out as obviously chafed/damaged - any input from the experts?
Thanks!
#3 ·
When I disconnected each battery, the cables ends looked fine, no corrosion at all. I cleaned them off anyway with a brass brush then electrical contact cleaner. Load tester for both batteries had them both still in the green, albeit not well into the green.
Let me ask you this - if I swing my Cummins around and hook up jumper cables to the rig, would that be sufficient to check? As usual, whoever installed the batteries in this thing (we bought it used last year) didn't bother to put a date on the batteries, so I have no idea how old they are.
New batteries are on the short list, but the ones I want are not available locally, so it will be several days before I can lay hands on replacements.
#4 ·
Another notch in the "I shoulda bought a Cummins" column. [Edit to add: I should point out, if I could buy one of these rigs with my 20-year old Cummins engine in it...]
That was it - my '05 Ram has the Odyssey Extreme AGM65 batteries in it, so I figured it was worth a shot. Spun it around, hooked up my big-dog jumper cables, fired right up. Well, not "right" up, it took a second to think about life, then it started.
At least the Cummins will do a slow roll when it thinks it's not getting enough juice.
OK, thanks for the tip - I would've spent far too much time chasing my tail. New batteries on the way.
I do still have to figure out what that issue is with the driver's footwell wiring harness, if I can ever replicate it again...
Much appreciated.
