wanting to get some opinions here on next course of action. Long story short bought a 2010 F250 with a cracked #7 pistons. Tore down did a total rebuild with Stage 2 DD60 completed bottom / top-end sent to machine shop. Did stud the bed plate and heads. Everything has preformed great, no leaks and all Short terms in Forscan look great.
The issue i am having is i get a High Fuel Rail Pressure interment. I have monitored the rail pressures and nothing is out of the ordinary. at idle calling for 5000 and its running 5090 to 4090. Starts just fine. I haven't done wide open throttle yet because of the fresh rebuild but running normal with a decent heavy foot on a hill its is running around 20000 psi, which seems normal.
Adding in here that i do not know how long the truck set with a half tank in it. I did add additional 15 gallons to full with Diesel Kleen.
Was wanting to get opinions on do you think i have a problem or would you run it a while longer? total miles since rebuild is 210 miles.
Thanks,
Rob
Thanks,
Rob
