2008 6.4 Transmission cooler lines leaking/replacement (do I need to lift engine 1.5"?)
16K views 5 replies 3 participants last post by  icegriffion
well if you get in a real bad spot remember these are low PSI lines so you can cut them and use transmission hose and clamps
I usually like to put a little of flare on the end for the hose clamp
