I have been back and forth between this forum and my truck. I got coolant leaking on top of the motor. It puddles up under the turbo and then leaks down the side and drips off of the starter. I have an egr delete and I have checked both the blue hose and the o ring on the egr delete and the coolant is not leaking from there. Where else could coolant leak from and puddle up on top of the motor??? I cant tell if the coolant puddles on the driver side. But it does on the pass. .
I noticed a slight leak weeks ago but it almost seemed to go away. I maintained the proper coolant level but it started leaking worse yesterday after a 7 hr drive. I added coolant while it was running then I shut it off. It leaked over a gallon out. With none in the d-gas bottle. This morning I put that gallon back in to see if it only leaked after it was hot and under pressure. ..... or if it would leak out after the truck sat over night. .. and yes it leaks soon as I added it back in...
ANY IDEAS??!!! once I can start taking things apart I will have more info..
