Is it possible to remove the fuel pressure regulator without pulling the entire fuel bowl/filter housing on a ‘96 7.3? I have a crack in the regulator where the fuel pressure sensor threads into the regulator. I would like to not have to pull and purchase the entire fuel bowl assembly. This image here is of the whole assembly, bowl and regulator. I have everything on the regulator unbolted and am left with the metal line on the bottom of the regulator. Does that detach?
