1992 ford f250. I have noticed a loud hum coming from the rear end when I let of the gas at any speed higher then 10 mph. If I apply a little bit of pressure on the pedal the noise goes away or isn't as loud. I was thinking something is wrong in the differential (ring and pinion) or something else. If it is the ring and pinion, how hard are they to replace and should I have a professional do it or should I just find rear end from the junkyard and swap it out.
Thanks for all your help.
