Who knows/used any good diesel shops??? Its about that time to do headstuds/egr delete and Im not sure if I should tackle this job myself. Im located in Suffolk county so the closer the better if i have to travel I will. Let me know guys. Thanks
I don't know of any good ones, but I will say STAY AWAY from Gabrielli Truck Sales. They couldn't even diagnose a high pressure oil system leak correctly. Cost me a grand for a new ICP sensor and it DID NOT fix the issue. I spent a few hours reading up on the high pressure oil system here and figured out my problem, then fixed it myself for under $100.
Yeah ive been tuned with innovatives street tune for a while now. Starting to piss coolant out of the over flow. Funny i never even thought of them and im right around the corner. Right now im just looking for prices. I'm buying the 6.0 solutions kit so bascially just need someone to install it.
You realize you need to find a machine shop capable of milling these heads? They also have to be checked for flat/straight and magnafluxed for cracks. If they mill the heads, they can not remove more than 0.008" to achieve flat, or the heads will have to be replaced.
The block surface should be checked as well.
Do this step, use stock FORD head gaskets and use the proper torque sequence and your head gaskets should last a very long time.
A little north of you but the dealer I work at does quite a few and warranty our work.Located in zip 12601.:thumb:
Related Threads
Ford Powerstroke Diesel Forum
posts
5.5M
members
295K
Since
2005
