Code problems unlocking converter
1.1K views 5 replies 3 participants last post by  08stroker250
I have some code issues that have just shown up that seem to be causing my updated tunes to be interupted. My converter is unlocking and shifting funny.
Can anyone advise me who knows how to fix these codes.
1. DTC code PO500 Vehicle speed sensor A
2. P1000, OBD system readiness test not complete.
3. UO100, lost communication with ECM/ PCM
I hope its just a bad connection.
Thanks guys C.J.
#2 ·
Don't worry about P1000, that is normal. U codes are communication codes, and they are tuner/monitor/wire related...not tuning related.
P0500 possible causes....
• Open in the VSS harness circuit
• Short to GND in the VSS harness circuit
• Short to PWR in the VSS harness circuit
• Damaged wheel speed sensors
• Damaged wheel speed sensor harness circuits
• Damaged ABS module
• Damaged PCM
C.J., your tranny/converter issues need to be talked over with the person who built the tranny. It doesn't have anything to do with the tuning.
