this is a fairly common problem on Excursions(maybe trucks too) that have the auto headlight feature and EATC..it doesn't happen often and the "cycle headlight switch" trick clears it every time..
i know back in the day someone had figured exactly why the relay gets hung up, but i've forgotten now..regardless, nothing is really broken and it's just a little quirk to have to deal with..
mine did it twice..1st time it came on 2 days later on it's own. the last time was last weekend and i thought if i turned the lights on maybe it would power up since there were no lights..and it has been working since.and i thought of it on my own..wow LOL not bad for a dumbazz lol
Mine does that crap, but only when it is hotter than the pits of HE!! inside the truck. I gotta try the headlight deal now. I usually turn the key on and off till the climate control works again, but with how high diesel is, that is an expensive fix....
My Ex has done that a few times. Now my auto climate control is just blow out of the defrost. I changed a relay under the hood and it worked for a few weeks. And Ideas??? I will try the head light thing.
That happened to me once, about a year ago and self fixed has not occured since. I'll keep the headlamp on -off trick in my back pocket. On trucks with automatic headlamps they have a sunload sensor that's also is an input to the HVAC, so it kinda makes sense that it could be related.
Mine has done it twice in 8 months and both times it has reset itself after restarting the truck. I haven't had a chance to try the light switch trick. Have heard of that in multiple forums. Gotta remember to remember that next time it happens.
My Superduty does it about once a year, at first I would just shut the truck off and restart it to fix it, but then I heard about switching the headlights between auto and off so I tried that the last time and it worked instantly!
Mine hasn't done it yet in 2009 so I figure it is due any time now.
Related Threads
Ford Powerstroke Diesel Forum
posts
5.5M
members
295K
Since
2005
