99 White/Blue Smoke
2.5K views 3 replies 3 participants last post by  richard1999
Hello all,
I have a 99 that blows a bluish white smoke basically all the time. Worse in the mornings but after it warms up its not bad. It does it at an idle. Smells like raw diesel. Just installed remanned injectors. 300 miles ago. Not sure if it smoked before I purchased it not running, a month ago. The only thing I have noticed is a gurgling noise when the ignition is on and the fuel pump is running. You can hear it in the pump and in the fuel bowl. Woud air cause these issues? Any input would be much appreciated. Thanks, in advance.
#2 ·
how many miles, how much blow by you have coming out the oil filler tube with cap off. Little steam or lots of chugging white smoke? Also you might want to run a compression test.
