6.0 Head Stud Part List.
110K views 174 replies 44 participants last post by  Saigachris
#1 · (Edited)
Well since I always get asked what parts I would recommend and where to get them as well as prices and part numbers I figured I would compile a list of parts for people to choose from for their head gasket and stud jobs.
ARP Head Studs: 250-4202 - $400-$450
OEM Oil Cooler Rebuild kit: 3C3Z 6A642 CA- Order from sunrisefordparts.com $269.43 shipped
BPD Remote Oil Cooler Kit - Price varies depending on what options you choose.
KEEP IN MIND THAT THE IPR Gen 2 EGR delete is NOT compatible with the BPD oil cooler kit.
IPR Gen 2 EGR delete kit: SKU: EGD-60GEN2B- iprresearch.com $259.99 + shipping
IPR High Flow Coolant Filter: iprresearch.com $249.00 + shipping
2003 Glow Plugs (LONG) need 8: 3C3Z 12A342 AA - sunrisefordparts.com $13.20 ea. $105.60 total
2004-2007 Glow Plugs (SHORT) need 8: 4C3Z 12A342 AA - sunrisefordparts.com $11.27 ea. $90.16 total
2003 - 2004
Glowplug buss bar right side: 3C3Z 12A690 BA - sunrisefordparts.com $40.80
Glowplug buss bar left side: 3C3Z 12A690 AA - sunrisefordparts.com $40.80
2004.5 - 2007
Glowplug harness left side: 4C2Z 12A690 BA- sunrisefordparts.com $40.80
Glowplug harness right side: 4C2Z 12A690 AB- sunrisefordparts.com $40.80
Updated Turbo drain tube: 6C3Z 9T515 A - sunrisefordparts.com $24.37
Updated Turbo Oil feed: 3C3Z 9T516 A - sunrisefordparts.com $87.50
Thermostat: 4C4Z 8575 AA - sunrisefordparts.com $28.60
6.4 Banjo bolts: w302472 Need 2 - sunrisefordparts.com $10.50
6.4 banjo bolt washers: w303659 need 4 - sunrisefordparts.com $3.60
Single alternator F-Series serpentine belt: 3C3Z 8620 DB - sunrisefordparts.com - $57.34
Main drive belt (Dual Alternators for F-Series trucks): jk8 1331 a - sunrisefordparts.com $49.82
Secondary drive belt: jk6 664 a - sunrisefordparts.com $25.34
Updated dummy plugs need 2: w302908 - sunrisefordparts.com $12.30 ea $24.60 total.
Updated standpipes need 2 (2003-2004.25): 3C3Z 6N853 BA - sunrisefordparts.com $51.60 ec $103.20 total. Comes with special standpipe for log style oil rails.
Updated Standpipes need 2 (2004.5-2007): 6E7Z 9A332 A - sunrisefordparts.com $45.60 ea $91.20 total. Keep in mind new head gaskets come with 1 standpipe with each head gasket.
There is also a "kit" that has both updated dummy plugs (2) and both updated standpipes (2): 6E7Z 9A332 B - sunrisefordparts.com $111.60
18mm OEM Head Gaskets: 3C3Z 6051 CB need 2 - sunrisefordparts.com $147.60 each, $295.20 total for both. Comes with new updated standpipe, new gasket and head locating dowels (each gasket has one of each and 10 TTY bolts).
20mm OEM Head gaskets: 6C3Z 6051 AA need 2 - sunrisefordparts.com $271.20, Comes with new updated standpipe, gasket TTY headbolts and head locating dowels. Sunrisefordparts.com*
DEPENDING on the MY of your truck you will either have 18mm or 20mm heads.
Build date before Jan 11, 2006 you have an uncommonized engine with 18mm heads and dowels.
Build date after Jan 11, 2006 you have a commonized engine with 20mm heads and dowels.
Water separator updated drain kit: 6e7z 9c082 a - sunrisefordparts.com $12.50
OEM Oil Filter: FL 2016 - sunrisefordparts.com $19.50
OEM OIL FILTER NOT NECESSARY IF YOU BUY THE BPD OIL COOLER KIT.
OEM Fuel Filter Kit: 3c3z 9n184 cb - sunrisefordparts.com $49.95
Exhaust manifold gaskets: 6c3z 9448 a need 2 - sunrisefordparts.com $21.22
CAC boots both hot and cold side. RIFFRAFFDIESEL.com I paid $140 shipped. If your cold side CAC (intercooler tube) is black plastic than upgrade to the metal one. 6c3z 6c640 aa sunrisefordparts.com $115.08
Injector o-ring kit: 3C3Z 9229 AA need 8 - sunrisefordparts.com $31.68 (if you send injectors to Jesse Warren you don’t need this part)*
Fleetgaurd Restore and Fleetgaurd Restore + cooling system chemical flushes. Can get at local big rig truck dealers (they can order it) usually around $23-$30 a gallon, need one gallon of each.
Zerex EC-1 Rated ELC fully formulated coolant, 1 case* buy it at NAPA Part number is ZXED-1 usually between $13-$20 a gallon times 6 in a case.
Rotella T6 full synthetic oil
I would also suggest updated ported rockers OR at the very least new plastic fulcrums for them.
For the rockers here is the Part numbers and prices.
Combination need 6 of these, 4C3Z 6564 AA - $52.80 each $316.80 total for all 6 @ sunrisefordparts.com
Single Intake rocker need 2 of these, 3C3Z 6564 BB - $44.40 each $88.80 total for both @ sunrisefordparts.com
Single Exhaust rocker need 2 of these, 3C3Z 6564 AB - $44.40 each $88.80 total for both @ sunrisefordparts.com
I would suggest push rods since it’s apart. 8c3z 6565 b need 16- sunrisefordparts.com $64.80
Depending on mileage it may be a good idea to replace the Roller Lifters.
Roller lifters with plastic guide and 4 lifters, need 4 of these sets: 8C3Z 6C329 A - sunrisefordparts.com $52.80 a set, $211.20 total
ARP Ultra Torque Lube 10oz bottle with brush*
Fumoto quick drain valve for the oil pan F-111n
Fumoto F-111N Engine Oil Drain Valve : Amazon.com : Automotive
Fumoto quick drain valves for the block plugs F-108N*
Assenmacher Specialty Trans Cooler Line Disconnect tool (Tool used to disconnect the lines going into the trans cooler part of the radiator).
Snap-on torque adapter tool for rear head bolt on driver side. SRD35 $55 + shipping
11/16 12pt 1/2” drive short socket for head stud nuts.
18mm 1/2” drive 6pt socket to remove head bolts.
Blue spring fuel pressure update: 3C3Z 9T517 AG - sunrisefordparts.com $57.60
Updated STC fitting for 2005-2007 trucks: 4C3Z 9B246 F $42 at sunrisefordparts.com
HPOP cover gasket: 3C3Z 6619 EA - sunrisefordparts.com $13.20
IPR screen update: 3C3Z 9H529 A - sunrisefordparts.com $30.00
IPR valve (2003-2004): 3C3Z 9C968 AA - sunrisefordparts.com $195.60
IPR valve if it needs replaced (2005-2007): 5C3Z 9C968 CA - sunrisefordparts.com $186.00 (can be found cheaper)
If doing head gaskets on a 2003 - 2004.25 I would suggest replacing the ICP sensor and pigtail as well while it is apart as it is buried under the turbo and it would be a quick swap while it is all apart. That and they are known to fail on these MY's.
ICP sensor (2003-2004): 3C3Z 9F838 EA - sunrisefordparts.com $114.00
ICP sensor (2004.5-2007): 4C3Z 9F838 A - sunrisefordparts.com $114.00
ICP sensor pigtail (also the same pigtail for the EBP sensor): 5C3Z 12224 A - sunrisefordparts.com $60.00
If you decide to replace the HPOP this is where I would get it (I got mine from here) it comes with the updated STC fitting as well as a new IPR valve and the HPOP (2005-2007 models come with IPR and STC fitting 2003-2004 only come with the pump).
2003-2004.5 HPOP: 3C3Z 9A543 AARM - sunrisefordparts.com has it for $564 +$150 core. Injectorwarehouse.com is $579.95 + $200 core charge.
HPOP-123X Ford Power Stroke High Pressure Oil Pump - Injector Warehouse
2005-2007 HPOP: 5C4Z 9A543 A - sunrisefordparts.com has it for $666.00 +$150 core for the pump only this place is $599.95 + $75 core charge and includes the updated STC fitting and new IPR valve with updated screen.
HPOP-122X Ford Power Stroke High Pressure Oil Pump - Injector Warehouse
If I forgot anything I will add it later lol.
Also here is a link to most of the parts/numbers anyone would ever need for their 6.0L incase I missed something that someone might need or want.
http://www.powerstroke.org/forum/general-6-0l-discussion/238358-6-0-parts-list-ford-international.html
And here is a link to my build thread showing how it is possible for one person to tackle this job in their driveway, by themselves, with limited tools AND wearing only FILPPY FLOPPIES, shorts and a tee shirt!
http://www.powerstroke.org/forum/general-6-0l-discussion/267064-shes-under-knife-my-build-thread-lots-pics.html
KEEP IN MIND NOT EVERYTHING IN THIS LIST IS "REQUIRED" TO COMPLETE THIS JOB. This is merely a compiled list of parts that are easily accessible while the engine is torn down this far for head gaskets should you choose to replace them.
#3 ·
The only thing I would add is iirc is that the IPR Gen II EGR delete will not work with the
IPR High Flow Coolant Filter kit with the manifold option.
#8 ·
As the saying goes you can't drink all day unless you start in the morning. Lol. But, it seems that's when stuff starts getting broken.
#9 ·
Perfect thanks for this
Sent from my SPH-L710 using AutoGuide.Com Free App
#13 · (Edited by Moderator)
If anybody wants to know what the ported rockers look like, they have a hole running thru the rocker arm tips to help lube the ball socket.
#14 ·
When were the ported rockers updated? What MY?
Sent from my iPhone using AutoGuide.com App
#15 ·
I don't know when, I think they were updated after they stopped producing the 6.0.
#16 ·
I see I see one more thing to add to list it's never ending lol
#18 · (Edited)
The part numbers for all the rocker arms in the list above is for the ported rockers. I have them in my truck. I bought all new rockers and push rods for mine when I did studs and gaskets. Also the way I understand it is the ported rockers actually push the valves open 1mm more than the old regular ones so I guess there is some added performance as well as reliability added with them.
#19 ·
Hell of a list I did all of that last month but don't like the IPR stuff. I went to the bulletproof stuff instead. I never got a CEL on the egr delete I lucked out.
#20 · (Edited)
Well the reason I put the IPR Gen 2 egr delete is because it is intact the best on the market as of now. It is a solid one piece design that keeps it from havin any weak links other than the o-rings where it seals. Only downside is that it's not compatible with the BPD Remote Oil Cooler Kit.
They also do offer the best coolant filter available and the fact that it is serviceable is a nice little add on.
Aside from those I agree BPD all the way for FICM's, water pumps and EGR coolers and oil coolers if your not going to maintain a OEM oil cooler.
#23 ·
Dumb question, can push rods be upgraded to a heavier duty type along with heavier springs without replacing lifters, or is it best to replace them also?
#24 ·
Not exactly sure if there is an upgraded push rod without getting custom ones made?? Good question though. I put 16 new push rods in along with all new ported rockers when I did mine just because. I was also planning on doing all new lifters as well but because I had 3 bad heads plus the cost of a new one I had to opt out of those as well as my other goodies.
#25 ·
Thanks. Was thinking aftermarket push rods since I'm in there anyways.
#26 ·
As far as I knew the OEM push rods aren't a weak link in the system. The only reason to upgrade to custom ones or aftermarket would be for a longer stroke so the valves open farther and are open for a longer duration. You would have to be VERY careful doing so though as if you take it to far than you seriously risk tapping valves and pistons.
