1 - 9 of 9 Posts
I have seen the Zoodad can be performed on later 99s, but is it possible to make one on a early 99. I tried searching for this but couldn't find anything
John Wood Nut Swinger
It can be done the same way as the later models. It will actually do some good if you have the air filter that pulls air from the front of the truck. If you intake pulls from the fender, don't waste your time on the zoodad mod.
i think i have the fender intake.
International Threat
do the tymar and zoodad and you're good :thumb:
what is tymar and zoodad mod.s heard alot on them but not sure on all of them
can it be done on early strokers? like 1996
any links??
yes you can do a variation of the DIY intake on the OBS not sure on the zoodad though
im going to make my own intake but whats tymar???
and what is the zoodad????
Click the link i posted above about the Zoodad it should show you photos. But you cut a hole on one side of the radiator support on the SD trucks where the intake draws its air from
1 - 9 of 9 Posts
