I put a rebuilt transmiision in my 99 Sd last september . I noticed it was starting to leak a little on the front seal area about a month ago .
when I put rebuilt Trans in I also put a new luk 07 155 clutch set and kevlar pilot bearing . The factory one is really bad and so is this one . I have put 65,000 on truck since doing work now I'm going to have to put in a new clutch and seal . Transmission has a little end play but I'm hoping it will be ok after I get the movement out of input shaft .
Don't let no one tell you the kevlar bearing/bushing is good ! IT a POS
Don't use one unless you want premature failure You look at picture theres a factory bearing a new kevlar one and the POS I just took out of my truck
