Two questions. does the oil pump in the ZF-6 spin whenever the clutch is engaged even with the transmission in neutral? Which one of the two oil pipes on the transmission is the return line?
I'm changing out the transmission fluid in my truck and want to flush the cooler and cooler lines at the same time.
