Like the title states, I want to start a thread for those of us that are running SCT Tunes in conjunction with a PHP FICM Programmer. What combinations work and don't work or you really like.
IDP's Extreme-X and Atlas 80 or Hercules. Since it is designed to run with a tuned ficm. It really doesn't like running PHP's Economy or Atlas 40. It makes the truck have an extreme light switch effect. And even effects shifting.
SRL-X runs great with all PHP tunes. It really comes alive with the Atlas 80 or Hercules.
I will regularly daily drive on TSD's Super Panty Dropper and PHP's Hercules 100. I'll get about 16 MPG mixed driving and nearly 19 out on the interstate. I will rarely use more than 1/4 throttle in normal daily driving and I have to be careful because it will roll smoke until the turbo spools. Careful throttle useage will keep the smoke at bay. This combination is hot and 1500 degrees on a hard pull is guaranteed. In normal driving it will run between 600 and 700 degrees.
I am currently experimenting with a Mild Panty Dropper tow tune and PHP's economy FICM tune. The truck is fairly happy but I have no solid information to report on this combo.
Sent from my DROID X2 using AutoGuide.Com Free App
I've been running Vivian's Looney tune with Atlas 80, great throttle response and don't need more than 18% PPS where as i used to need 22-24% to get up to speed. EGT's cruising were 630-700.. could bump em up when i rolled on throttle and saw as high as 870-950 at 50%+ PPS. Lie-O-Meter showed 1.5mpg increase no real world calcs yet
I loaded economy tune to see what highway numbers are since im going to be making a 750 mile trip at end of the money. i will hand calc that trip and post more once i get to run the truck (loaded the ficm and left it sitting)
Discussion Starter · #4 · (Edited)
Xtreme-X is just smokey in general, but with Hercules, at wot its laying down a pretty good haze. normal acceleration its hazing.
srl-x actually got less smokey all around. at wot it used to put down a pretty good haze. with ficm tuning its clean.
Xtreme-x would not make more then 25 lbs of boost without ficm tuning now its seeing 33lbs. I actually blew an IC boot for the first time today. IM not sure what its actually making since i don't have a mech boost gauge. :dunno:
Also it was raining this morning. I was going 50 mph. tc locked in 4th ( im in town mind you) i got into it a little, very far from wot, id say 50% and the truck went sideways :hehe: it will spin like its on ice at any speed. well under 55. its so responsive its insane
