1 - 18 of 18 Posts
Hey all,
Been readin (lurking) my a$$ off for bout 2 months since my 6.0 came up the road lookin like a Stanley Steamer! Since then, thanks to your posts, I've installed the Bullet Proof EGR & oil cooler and some other various do-dads. Love the Bullet Proof, love the new Edge CTS I installed tonight!
Here lies the mystery. I read alot about oil/coolant deltas being 3-10 degrees, 15 being critical. Is this because the oil cooler is water cooled and 15+ indicates trouble? Or will 15+ cause damage somehow?
I now have an EXTERNAL oil cooler and my new CTS monitor showed huge deltas for 25 minutes of warm-up. Temps. are as follows...
5 min. warm up, 5 min. downhill.......................................delta 15-20*
15 min country drive, med accels..oil 155...coolant 188.......delta 33*
Idle 5 min.................................oil 170...coolant 186.......delta 16*
Regular country driving...............oil 185...coolant 188.......delta 3*
5 min drive uphill, low airflow.......oil 196...coolant 200.......delta 4*
Parked.....................................oil 205...coolant 200.......delta 5*
After 5 min cool down.................oil 203...coolant 188.......delta 15*
I've never heard of deltas being this far apart , but I've never heard of anyone speaking of warm-up. Is this normal? Does my EXTERNAL oil cooler make a difference? Will these deltas hurt my shtuff?
Thanks for sharing all your experience and opinion, $aved me a bunch on diagno$tic$ and labor!
Richard
Hey all,
Richard
Richard
Your deltas are the other way around must be from the oil cooler EXTERNAL to me they look good the only one is the coolant it's low because the t/stat does not open tell 192.2* did you install a new one if so i hope it was a Ford
Lookes good to me Mitch PGreenSVT should know he has the same setup.
2 stroker
Your fine - no worries. The 15*F delta was a parameter Ford identified to be an indication of the "Water Side" of the oil cooler plugging up.
Absolutly a factory new tstat. Thanx man, was hopin to hear from Mitch too. I was expecting to see oil warm up faster than the coolant.?. I dunno
Thanx bismic, I was hopin to hear that it INDICATES a problem, not CAUSES a problem.
negative deltas
Here lies the mystery. I read alot about oil/coolant deltas being 3-10 degrees, 15 being critical. Richard
Almost all of your deltas are negative deltas. Meaning no problems as far as overheating the EGR cooler. A positive delta of 15° or more is the point of concern. Even at that, you now have the BPD EGR cooler so you are miles ahead.:thumb:
One thing I think you missed is when that 15* delta makes a difference. Based on the above it looks like you were taking temp readings at various "around town" driving scenarios.
The proper way to test the delta is to get your truck to operating temps and then drive at 65 mph on the highway. That is when you test the delta. Driving around town, especially in hilly areas, won't give you a true gauge of your ranges. Your "regular country driving" could fall into this (country driving here is 65+) and if so then it looks like you're right where you should be.
As explained above, the significant difference in temps during your warm up is due to the thermostat not being open and you, technically, not being up to "operating" temps.
Thanks Acidsniper. I'll put er on the highway tonight.
Mark. With my external oil cooler the standard deltas mean little to me, right?
correct. In your situation, you should just look at each individual temperature. Get to know what is normal and what isn't - as it relates to your specific truck.
Hey all,
Very normal. Did you get the cold weather kit (thermostat) as well? If you live in a colder climate, that will help oil temps warm up quicker.
The delta temp has no meaning for someone with an air cooled oil cooler.
And of course I missed that part even though it was in all caps in the OP...
:doh: Don't mind me I'll be over here -> :popcorn:
bismic is correct. The 15* delta only matters if you have the oem oil cooler.
Rodeo there is nothing the matter with your temps and you are fine. You no longer need to consider the delta, just the individual temps. The oil warms up slower than coolant depending on external temps. Yesterday in 90* temps I was seeing coolant temps of 201 and oil temps of 205 or 206. The engine is happy as a clam with those temps.
Discussion Starter #15
No Gene, I'm in sunny SoCal
Discussion Starter #18
Sorry, hope y'all get along:dunno:
Thanx for the info, squashed alot of new fears the CTS gave me. Maybe I'll start to feel the love for the stroker again. That 6.7 Longhorn sure was sexy tho...
1 - 18 of 18 Posts
