1 - 8 of 8 Posts
Do i need to remove anything to re seat my y pipe to my turbo? I have a leak there but don't want to tear it down to fix it. Just finished my delete studs and oil cooler.
Sent from my DROID RAZR using AutoGuide.Com Free App
Loosen all the bolts on the turbo and y pipe, align the pipe, do not use the clamp to pull it up. Once the pipe is set, tighten the clamp. tighten the turbo bolts.
I tried that but i always have about a 1/4 inch gap i can't seem to close and get the turbo to seat.
You are not alone.
When I reconditioned my turbo I had this same problem. It took three times of breaking the turbo loose and realigning. Break out the swear jar, band aids for the knuckles, some beer and a lot of patience.
While I do not highly recomend this I once had to take a block and 2x4 and pry gently against the cab to bend the flex forward a bit.
Do not use a lot of force just steady pressure. Once again only as a last resort.
Note: Tranny was removed for access and control of the 2x4.
Discussion Starter · #8 ·
I'm thinking of trying the ratchet strap and slowly pulling it forward.
1 - 8 of 8 Posts
