1 - 18 of 18 Posts
ok i have had a wicked wheel now i have not had time to install i need help okay whats the easiest way i took the four bolts off how the heck do i put the bottom one back in its hard to get to ya know then i could not get the shell apart like it hit a bolt i was really really close what do i have to do am i missing someting please reply
Stupidity pisses me off
Yeah the bottom one that the wrench or socket hits the valve cover? You need a swivel socket, or just some patience and have to do it with a hand wrench. Look into the 7.3 mod forum. Somewhere in there is a complete discription of the WW install, and there is also a video.
Yeah, that's the video!
Can you describe what it is hitting?
Wait, did you say early 99?????
THE EARLY '99 HAS THE WW FROM THE FACTORY
Discussion Starter · #10 ·
okay it wont let me show pics but okay the bolts there is four 8 MM 12 point bolt mine one is dead *** at the bottom of turbo so its really really hard to get to i could not even put it back it i need to i got all the bolts out and the housing was free but was hitting a bolt or some this whats the best way i have early 99 if that makes a diff
If you don't have the right tools, worst case cenerio is you have to remove the valve cover for your clearance:dunno:
you need to upload your pics to photobucket or webshots or imageshack or something before ya can post em...
pics would definately be helpful
pics needed...y are you putting a wicked wheel in an early 99?
yes, the same "style" wheel as a WW comes on the early 99 models
Discussion Starter · #16 ·
I got it done and the wheels are not the same i ordered this one from laguna speed not the same it spools alot louder sounds bad ***
Not to start any thing here, but why are they not the same? Are you sure yours is an early `99?
just asking
later
1 - 18 of 18 Posts
