2KF2507.3PSD250KMILES
I HAVE been running wvo for 150k
70degrees in garage
yesterday morning truck wont start,
is parked in garage, shut off on diesel, been running great,
checked oil and it was sticky and thick on end off dipstick
tried to change oil, wouldnt come out, plugged in engine heater for 24hrs
looks like wvo and oil mixed in engine
oil drained out in big blobs, changed oil and filter, truck starts right up, but runs poorly, removed valve covers sticky stuff all over,
how can i clean inside of engine
and where is wvo getting in oil
thanks for your help
In response to the OP, gunk in the crankcase from running WVO-based fuels si not uncommon. The cause is blow-by brings the WVO into contact with your motor oil. WVO and motor oil make glue when combined. The cause of the blow-by is coke accumulations in the engine from running high ash content fuels, or improper combustion, and/or both.
call me nuts ... just do it now and get it over with but I will share the "trick" I learned several years ago taught by an old school wrench.
To get the goop out, drain what you can and top off the crank case with diesel. Crank it. If it fires up, let it run! Shut it down and drain it all out. Then refill with mostly diesel and a quart of marvel mystery oil. Crank it again ... if it runs, let it run no more than 5 minutes. Shut it down and drain. You ought to get all the old sludge and goop out of the engine. Fill with cheap oil and drive 50 miles. Drain that out and replace with Rotella and a new filter and you will have cleaned it out.
I regularly use this method of flushing my engine out to remove crud, and dirt, before replacing the oil filter and motor oil.
However, unfortunately the sludge that is the product of WMO meets WVO is not soluble in petroleum distillates. It is liquid at 160F, so heating the engine and creating a cold trap where the crud can collect does work.
The coldest parts of the engine are the valve cover, oil pan and oil filter. So, the if the valve cover and oil pan were insulated, while a oil filter were actively cooled with a fan, then it might be possible to run an engine up to operating to force the sludge into the oil filter. I have done various experiments like this with one of my engines and it worked fine, but it took several oil filters to collect all of the sludge.
Here are photos of the sludge I removed from one of my research engines with this problem.
This is what came out of the oil pan when I put a hot plate on it overnight
This is what came out of my fuel tank after a WVO+WMO blending experiment
This is sludge in my fuel line from that experiment
